Offroad & 4x4
under water help!!!
Old May 27, 2003 | 08:39 AM
IcedBronco's Avatar
IcedBronco
under water help!!!
what to do after going through 5ft of water in my bronco it clicks and lights flick any ideas?
i have 3" body lift and 33's
help
it sat over night maybe dried out
but as soon as i hit the water it stopped running
snorkel is in the works now
Old May 27, 2003 | 11:33 AM
77'F-150Mudder's Avatar
77'F-150Mudder
under water help!!!
What year is your Bronco?
Old May 27, 2003 | 11:38 AM
IcedBronco's Avatar
IcedBronco
under water help!!!
83 5.0
Old May 27, 2003 | 12:28 PM
RRMike's Avatar
RRMike
under water help!!!
Did you get water in the air intake
Take your spark plugs out and turn the motor over and push all the water out of the cylinders??
It won't turn over if the cylinders have water in them. Also change oil. It's probably full of oil by now if you got it sucked in the intake.
Then just hope the rods aren't broke.
Old May 27, 2003 | 12:32 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
under water help!!!
Drain and change every fluid in the thing, oil, power steering, tranny, coolant. front and rear differentials...
As was mentioned before, remove ALL of the spark plugs slowly rotate the engine, and use a shop vac to make sure you get ALL of the water out of the cylinders.
And yes. Pray that there isn't a broken rod. Do NOT try to start it because if only one cylinder has water and it fires, you're going to look like this dude..-->
Old May 27, 2003 | 01:01 PM
trojanman25's Avatar
trojanman25
under water help!!!
and make sure your alternator is ok, mine goes with an ounce of water
Old May 27, 2003 | 01:48 PM
77'F-150Mudder
under water help!!!
Also pull the distributor cap and spray some WD-40 under the cap and in the dizzy to dry it out.
It sounds like you got the electrical system wet. Go through the whole thing plug by plug and blow them out with compressed air. Did you get water in the cab? You fuse box may be soaked.
Old May 27, 2003 | 10:44 PM
Ryan50hrl's Avatar
Ryan50hrl
under water help!!!
hey dude....ya know boats float alot better.....
Old May 28, 2003 | 12:54 PM
IcedBronco's Avatar
IcedBronco
under water help!!!
i got it running last night
no water in te motor but there was a faulty batt clamp and i sprayed with wd 40 and it is back going
need to change fluids i did ceck water in clyinders
it won't be swimin again for a while
Old May 28, 2003 | 04:43 PM
bugeyed's Avatar
bugeyed
under water help!!!
put silicone around your electrical stuff, i did and it helped alot.
Old May 29, 2003 | 04:15 PM
66MercMan's Avatar
66MercMan
under water help!!!
All crutial components have breather lines. If you are getting a snorkel and want to put this thing in any water at all, make sure to run hose from the breathers on your diffs, tranny etc into your cab. If you use silicone like bugeyed suggested on electrical and around your plugs and have good weather stripping around your doors you should be able to go through a lot of water. If you don't have breather lines ran properly it is very easy to get milky oil in your axles and it can be very difficult to clean it all out. I've been hood deep before and I wished I had my breather lines higher than I did. It would have saved me alot of time and effort.
Safe Swimming!
Old May 30, 2003 | 01:06 AM
ckrichard's Avatar
ckrichard
under water help!!!
Safe Swimming!
Or next time try finding a shalower part of the river/pond.
Chris
Old May 30, 2003 | 06:46 AM
bugeyed's Avatar
bugeyed
under water help!!!
shallow! whats the fun in that? lol
calebsnow
Nov 15, 2015 09:52 PM
wtx66f100
May 23, 2015 09:14 AM
johndeere46
Mar 7, 2013 05:42 PM
95PSDieselP
Dec 23, 2011 11:49 PM
twiztedford
Sep 3, 2009 06:30 AM
