Sponsored by: Real Truck
Locking diff...who can explain this??
Old Jan 7, 2013 | 10:59 AM
Amelio's Avatar
Amelio
ok I am lost on this one....when the diff is locked...... its locked I do not understand what is happening here.....who can explain why the diff is not locking on the Ford?
Old Jan 7, 2013 | 12:17 PM
Firekite's Avatar
Firekite
I'm not sure what's up with the ramp in the first place. Rollers on one side, I assume?
Either way, clearly if the truck is equipped with an E-locker it's not engaged. In mine it's very clearly felt on high-traction surfaces (asphalt) and walks up loose dirt and small-rock-strewn hills steeper than that ramp. And there's no drama you get from an LSD-like locker. It's just on before I start. I'd love to run that ramp in my truck and figure out WTF they're trying to pull with that. Fishy.
Old Jan 7, 2013 | 01:42 PM
Amelio's Avatar
Amelio
yeah its got rollers on the driver side and regular steel grate on the pass side.....they are testing the diffs in all 3 trucks. You can hear the guy say that in order to lock the diff in the Ford you pull out the 4x4 switch.
Now did they do that or did they leave it in.....I know the chevrolet locks the diff by somewhere around 7mph difference in each wheel. I have locked the diff in my truck just to play and it is a true locker as I understand it to be so I am lost as to why their truck could not make it up the ramp.
Also why did they have it in 4 wheel drive and left the chevy in 2wd??? I wonder did they switch it to 4wd but not pull the switch out to lock the diff? Obviously that is not gonna work....if they expected it to lock like the chevrolet based on slip then no it will never lock and the results are what we see.
Is there a Ford engineer here to explain this? When pulling the ELD switch out it is a true locker correct?
Old Jan 7, 2013 | 02:52 PM
Firekite's Avatar
Firekite
Defining a "true locker" can be a little difficult. The Auburn ECTED is technically a true locker but uses clutch packs like a limited-slip but forced to engage when enabled.
Old Jan 7, 2013 | 04:22 PM
Amelio's Avatar
Amelio
so whats your opinion on this? do you think they left the ELD unengaged? The ELD is standard on the 4x4 super duty correct?
This just does not make sense.....if the rear does not lock then whats the use of having it?
I personally think they left the ELD switched off or the truck was not equipped with it (I doubt it I am sure it is standard on a 4x4)
Old Jan 7, 2013 | 04:29 PM
SteveH-CO's Avatar
SteveH-CO
From my GM buddies, I have learned that Gov-locks tend to blow up in their later years, which isn't a vote in their favor. It's not a horrible design, but like all lockers, it's not perfect either. I think it requires a 100 rpm difference in wheel speed between the slipping and the non-slipping side to engage, which is why you hear the clunk.
Old Jan 7, 2013 | 06:45 PM
Tom's Avatar
Tom
Myth BUSTED!
This video is deceptive and misleading at best.
To start off they can't even spell Cummins, see below. How can this source be considered credible if they can't even properly spell one of the most well known engine manufacturer's names?
Secondly did you guys notice that the truck was a DRW truck? The electronic locking differential is not available on a DRW truck. That's most likely because the DRW truck uses a Dana rear axle which is completely different from the Ford designed and manufactured axle for the SRW trucks. The two axles share nothing in common, so it makes sense why the ELD wouldn't be available.
Proof that it wasn't available from the factory is below, taken straight from the 2011 Super Duty order guide. And proof that it didn't have an aftermarket locker installed can be seen in the video.
Old Jan 7, 2013 | 06:58 PM
Amelio's Avatar
Amelio
ok thats it....Thanks Crazy001!!!!!
I thought this video was BS when I saw it but I could not understand why the diff was not locking. Ok so the DRW is not equipped with ELD....mystery solved.
I am a GM fan I have had 4 GM/Chevy trucks one used to be an '04 Dmax.....I like GM Still but I chose the Ford for many reasons you guys aleady know.
I hate to see videos like this trying to show which truck is superior and then not compare equally.
Bogus video and very lame on the people who put this video together!
Old Jan 7, 2013 | 07:01 PM
Tom's Avatar
Tom
+1.
I have absolutely no use for blind brand loyalty, but well done objective tests can be great tools for comparison. But blatantly misleading everyone like that makes it far from objective, although the misspelling of Cummins lends credibility to the idea of simple incompetence rather than intentional deception.
Old Jan 7, 2013 | 08:24 PM
EXv10's Avatar
EXv10
There are a lot of different locking differentials now days and years ago it was just the posi-traction and the limited slip. That demonstration was as deceptive as the ads you see about vacuum cleaners. If all those trucks started 5 feet back (on the pavement) at full throttle they would have all gone up the ramp locked. They just have different characteristics and they capitalized on it with the phony ramp demo. "If you order now we will send a second one free, but wait!"............lol.
Old Jan 7, 2013 | 08:57 PM
Yahiko's Avatar
Yahiko
A vacuum cleaner salesman was the first thing that came to mind when I
watched that video. If you stack the deck even Joseph Stalin
can look better.
That is one reasons I don't trust advertising and political polls.
Sean
Old Jan 8, 2013 | 12:10 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by Crazy001
+1.
When I saw them roll out the dually, I immediately smelt something fishy.
You can hear the guy say it has a locking diff, but as we know, it did not. Also, leaving the Chevy in 2wd? That wouldnt have made a difference anyway. Just trying to make the Chevy seem all that much better lol
Old Jan 8, 2013 | 12:12 AM
EXv10's Avatar
EXv10
can look better.
Sean
I have never bought anything I saw on TV so they could have skipped all those ads since 1955 and it wouldn't have made a difference. Political polls; people just vote for whatever they think will help them or whatever might help their kind.........if you know what I mean.
Old Jan 8, 2013 | 08:05 AM
Quad Racer's Avatar
Quad Racer
That video was entertaining. Even if it wasn't a scam I wouldn't buy any other truck. Those trucks are plain fugly. I noticed they left out the crappy front suspension. No comparison's there, huh chevy guy.
Old Jan 8, 2013 | 12:34 PM
EXv10's Avatar
EXv10
Rest assured, it was a scam. I have seen this same kind of scam before. Some diffs are just a little more sensitive at first than others.
