Expedition
Old May 27, 2003 | 04:52 AM
PBADOME's Avatar
PBADOME
Question Expedition
I have this vehicle for two weeks, 2003 Expedition, and I notice that between 20 and 30 miles per hour that there is a humm or vibration from the engine or tranny. Above 30 or below 20, it stops. Then above 40 I feel it again. This is felt mostly on deceleration. It's as if the engine is still revving, but it's not. Can you tell me anything about this?
Thanks.
Old May 27, 2003 | 06:06 PM
2003EXPY's Avatar
2003EXPY
Expedition
If it's a 4X4 try putting it in A4WD and see if the problem stops. If it does you have the growl/vibration that affected most of the 4X4 2003 Expys,take it to the dealer and they can fix it under warrantee. Ford has a TSB concerning front axle growl.
Old May 28, 2003 | 06:59 AM
FiremanRon's Avatar
FiremanRon
Expedition
This sounds similar to the proplem I had with my 03 xlt with <500 miles. The dealer replaced something with a "revised part" and the vibration went away. Ford apparently knows of the problem, because the dealer first told me the differential would need replaced, but that was before they talked to the Ford rep. It was in the shop for half a day, once they figured out what it was. Mine growled both 2wd and 4wd, from 15mph to around 45.
Old Jun 11, 2003 | 06:08 AM
deadeyedenny's Avatar
deadeyedenny
Expedition
2003EXPY is correct. Ford has a bulletin 02-25-7. They install a S-spring into the front differential to make the halfshafts rotate at the same speed. I had my 2003 repaired after waiting three months for Ford to figure it out back in February.
Old Jun 11, 2003 | 06:53 AM
PBADOME's Avatar
PBADOME
Expedition
Thanks, I had that taken care of last week. I brought them all the paperwork about the Bulletin because they seemed to be unaware. What I don't understand is why Ford, knowing of this problem for eleven months, has not done more to educate their dealerships. Or, Heaven forbid, fix the problem before they sell the car. I buy American, but these companies really do test my patience.
Old Jun 11, 2003 | 06:59 AM
deadeyedenny
Expedition
The problem does not affect every Expedition. Mine started the first time I used 4X4 in 10" os snow and the truck had over 7,000 miles.
Old Jun 11, 2003 | 08:31 PM
PBADOME's Avatar
PBADOME
Expedition
thx, I'll keep that in mind for my cousin's Exp.
Old Jun 14, 2003 | 05:43 PM
tolson37's Avatar
tolson37
Expedition
My 2003 Expy has < 3000 miles and the growl / hum is becoming very noticeable. What is the best approach for getting the dealer to recognize and fix. What everyone has been saying is definitely true? Does anyone know the exact TSB my Ford dealership should lookup??? Thanks in Advance-- I want to get this fixed before I go on a 4000 mile trip across the country in it...
Old Jun 14, 2003 | 10:38 PM
PBADOME's Avatar
PBADOME
Expedition
This is from the NHTSA website:
FORD Model : EXPEDITION Year : 2003
Service Bulletin Num : 16070 Date of Bulletin: JUL 01, 2002
Component: POWER TRAIN:AXLE ASSEMBLY
Summary:
SOME 4X4S MAY EXHIBIT A FRONT AXLE GROAN OR HUM, AND / OR A SLIGHT VIBRATION WHEN OPERATED IN 2 HIGH MODE. *TT
ALSO:
Make : FORD Model : EXPEDITION Year : 2003
Service Bulletin Num : 16088 Date of Bulletin: JUL 01, 2002
Summary:
SOME 4X2 VEHICLES MAY EXHIBIT A REAR AXLE WHINE AT 50 AND 62 MPH IN COAST OR DRIVE. *TT
Good Luck.
Old Jun 15, 2003 | 07:44 PM
tolson37's Avatar
tolson37
Expedition
Thanks PBADOME... Appreciate it... I'll let everyone know of the outcome.. I'm taking it in this Tuesday morning... See what kind of diagnosis I get from the local Ford dealership...
Old Jun 16, 2003 | 08:38 PM
PBADOME's Avatar
PBADOME
Expedition
Don't take no for an answer. there is a problem and they are obligated to repair it.
mjkorcek
Mar 24, 2016 04:31 PM
EPI-911
Oct 3, 2015 07:46 PM
idcpa
Oil & Lubrication
25
Dec 27, 2005 07:06 PM
laswalker
3.0L V6
Aug 8, 2005 06:41 PM
fordsrbetr
Oil & Lubrication
Feb 15, 2004 07:57 PM
