flywheel/trans cooler
Old Jan 6, 2013 | 04:00 PM
69 f-100 aman's Avatar
69 f-100 aman
Hey,I changing my truck from a standard shift(t-18) to a automatic trans (C-4) a friend has a flywheel from a 250 six and I have a 300 six will this flywheel work in my truck?I also would like to know if I put on a hangon tranny cooler is that enought to cool the trans or do I need to change out the radiator with a trans cooler in it.... Thanks
Old Jan 6, 2013 | 04:13 PM
jowilker's Avatar
jowilker
Auto trannys us flex-plates rather than flywheels, totally different. Also there is a pilot bushing in the end of the crank that has to be removed.
The hang on cooler should be enough.
John
Old Jan 6, 2013 | 04:31 PM
69 f-100 aman
John
what is the differants between a flywheel and a flex plate and I look on the Makco web site and they dont list flexplates.
Old Jan 6, 2013 | 06:26 PM
rustywheel68's Avatar
rustywheel68
flywheel- big heavy plate that the clutch bolts to.
flexplate- thin plate that does nothing except get turned by the starter.
Old Jan 6, 2013 | 07:09 PM
RichS2659's Avatar
RichS2659
The most glaring thing here is that the 250 and 300 are two completely different engine families, the small six and big six. The small six consists of the 144, 170, 200, and 250. Very few parts interchange. The big six consists of the 240 and 300. They each have different bellhousing patterns with the small six having their own with some 250's being made with the small-block V-8 pattern, IIRC. The 240/300 uses the small-block pattern, so henceforth different flywheels/flexplates. Unless his friend has a 240. The easy way to tell the difference between the two is that that the small six has the intake manifold cast as a part of the head, whereas the big six has a separate intake manifold.
Old Jan 7, 2013 | 06:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 69 f-100 aman
Hey, I changing my truck from a standard shift(t-18) to a automatic trans (C-4).
A friend has a flywheel from a 250 six and I have a 300 six will this flywheel work in my truck?
No.
C5TZ-6375-T .. C4 Flexplate* / 164 teeth / 4 converter attaching holes on an 11 7/16" bolt circle.
Applications: 1965/71 Galaxie/LTD 240 I-6 // 1965/77 F100/250 240/300 I-6 / 1965/74 F350 240 I-6 / 1965/67 Econoline 240 I-6 / 1969/77 Econoline 240/300 I-6.
Note: 1965/72 F350 300 I-6 uses MX Cruise-O-Matic / 1973/77 F350 300 I-6 uses FMX Cruise-O-Matic / 1978/79 F350 300 I-6 uses a C6 // 250 I-6 installed in misc 1969/80 Ford/Merc Passenger Cars only.
* I typed Flexplate to avoid confusion, but FoMoCo never used that term. All M/T & A/T's are flywheels.
Old Jan 7, 2013 | 10:23 AM
kenny nunez's Avatar
kenny nunez
pilot bushing
69 F100 , To remove the pilot bushing, drill a bunch of holes in it to perforate it so that it can be broken apart with a chisel. Good luck, Kenny
Old Jan 7, 2013 | 03:54 PM
69 f-100 aman
Thank You, Thank You, Thank You!!!!
Old Jan 7, 2013 | 03:58 PM
69 f-100 aman
Thanks,I alreadly new how to do all that,I was told way back to fill with grease and then put pilot shaft in the hole and knock the **** out of it...
joegeds
Apr 1, 2015 03:34 PM
TexasTornado66
Oct 21, 2011 11:40 PM
outsource77
Jul 2, 2009 02:29 PM
aspork42
Jul 6, 2004 03:15 AM
Jim79
Aug 10, 2003 09:38 PM
