98 explorer 4x4 no reverse
Old Jan 5, 2013 | 09:14 AM
65jim's Avatar
65jim
Hello, I have a 98 4door 4x4 auto.Reverse stopped working a year ago. The forward speeds work perfectly. I hate to have to rebuild the entire trans. I've been driving it some,being careful where I park,but getting tired of it. My question is do you have to pull and take the trans all the way apart to fix this?
Old Jan 5, 2013 | 09:47 AM
Jigger2020's Avatar
Jigger2020
Yes the trans has to come out & apart........does it hold in park OK, its not just the linkage is it
Old Jan 5, 2013 | 07:45 PM
Ford_Six's Avatar
Ford_Six
It may not- If the problem is the reverse servo, that can be accessed just by dropping the pan. I have seen some references to a reinforcement plate for the servo cover, and a tendency to blow out the servo cover gasket. It's much more likely to be a hydraulic issue than a band problem.
Old Jan 5, 2013 | 08:07 PM
Jigger2020's Avatar
Jigger2020
Drop the trans pan & the rev servo is right there (4 bolts on the cover), pull it out & have a look, if it looks fine then the trans will have to come out.......
Old Jan 5, 2013 | 08:34 PM
65jim's Avatar
65jim
Thanks Gigger and Ford-six.It would be great if for once I could have a simple fix.. I just hate spending $1200 to $1500 on a $3500 vehicle.Yes,it goes into park just fine.
Old Jan 5, 2013 | 08:37 PM
Jigger2020's Avatar
Jigger2020
We understand Jim, the problem is most likely the high/reverse clutch but you may as well have a look, did you check the linkage & the shifter cable
Old Jan 5, 2013 | 09:12 PM
65jim's Avatar
65jim
I am going to check it out hopefully this week. It probably is the clutches, but it didn't gradually get worse. I just put it in reverse one morning and it just wasn't there . Before that it worked fine.All other gears....perfect.
Old Jan 5, 2013 | 09:56 PM
Jigger2020's Avatar
Jigger2020
Yup, thats the way they go.........good luck
whiskey runner
Feb 13, 2011 08:15 AM
47studebaker
Mar 14, 2008 10:32 AM
bobbydrums53
Dec 1, 2003 04:16 PM
