Sponsored by: Real Truck
OE Sway Bar End Link Replacement with Pics
Old Dec 4, 2017 | 03:39 PM
  #31
geekwithoutacause's Avatar
geekwithoutacause
Originally Posted by Y2KW57
In my opinion, a cross axis ball joint allows for more articulation and flexibility within the allowable range of motion, and more rigidity and resistance to sway when reaching the limit of the allowable range of motion... than a solid urethane bushing.
The problem with the original production cross axis ball joints appears to have been a failure of the seal membrane. The later replacement and service part sway bar end links with the cross axis ball joints appear to have a more durable sealing membrane, that remains in tact for longer than OEM.
The cap seals of my replacement Ford service part sway bar end links have already lasted longer than the original seals of the OEM parts they replaced. If anyone considering new sway bar end links has the patience to trust that Ford got it right the second time around, or that MevoTech and other currently available sway bar end links with cross axis ball joints have seals that will go the distance... I think the ride and handling will be more comfortable and controlled with articulating joints over bare bushings.
I've installed the bushings and I don't think it was less comfortable or less controlled. Of course it could have been just me enjoying the quiet ride compared to the clunking and squeaking before. I first did balljoints and the first test drive after that was on a cold morning. It squeaked pretty bad which turned out to be the endlinks and/or swaybar bushings. I really enjoy the quiet ride now. Night and day difference. I can always trn back to oem end links, they're not expensive.
Old Jan 28, 2020 | 07:52 AM
  #32
sidevinder's Avatar
sidevinder
Hi, I found the Ford OEM pillow block part number for a 2001 Ford Excursion: YC3Z-5C495-AA Stabilizer Link Bracket. It sells for about $27.
sway bar linkage frame mount - 2001 Ford Excursion 4WD
Old Dec 6, 2020 | 10:47 AM
  #33
Brandon Heineman's Avatar
Brandon Heineman
Life saver
A few installation details for the right (passenger/curb) side:
The starter being in the way took me by surprise. It is possible to resolve this interference issue much more expediently than shown above... by simply reversing the bolt direction... ie by threading the bolt through the frame first, such that the bolt head is outside the frame web, and the bolt threads are pointing toward the starter.
For whatever reason, Ford did not install the bolt that way, so I didn't either. That meant the pillow block had to be temporarily unbolted in order to replicate the way Ford originally installs the bolt. Also, if using the Ford factory OE link, the top bolt comes pre-pressed into the bushing. It is not known if the force to press or brute force hammer the pre installed bolt out of the bushing is equal to the force that would unseat the bushing itself from the end link eyelet.
I did not want to risk unseating the bushing in side the eyelet, because the bore diameter of the eyelet is continuous, with no stop or step inside. That is one reason why the photograph of the eyelet circle without a bushing is posted above... to illustrate smooth bore with no steps or stops. When pressing in a SACHS replacement bushing that does not have a two tier diameter like the simpler urethane aftermarket options have, it might be important to know when the bushing is pressed in enough, but without a clearance calibrated jig fixture, how would one know?
This issue is likely one of the reasons that Ford, Moog, Raybestos, and Mevotech sells the entire endlink with bushings pre pressed into place. Two step urethane inserts are self calibrating... ie, shove them in until the second step is flush with the edge of the eyelet ring. The more sophisticated greased ball joint type of bushings, such as the OEM versions from SACHS, are continuous diameter with no step.
I post this seemingly obvious and arcane detail because there was a gap in my understanding about this subject when I researched other's experiences replacing the bushings. I came to realize that different people were talking about different bushings, mostly aftermarket options. It seemed useful to put up some clarity for those considering OEM options.
Up next, in a day or so, will be pics of the driver's side installation, as well as the addition and modification of more bushing heatshields.
Man i was trying to figure this out for days. You juat saved my life getting the F350 back driving
Tbug05LTD
Jul 17, 2019 09:13 PM
anthonym92
16
Aug 2, 2015 05:07 PM
Giorgi
Oct 7, 2013 06:18 AM
1975StroppeBaja
Jun 15, 2008 05:29 PM
sgrol
Apr 21, 2006 05:56 AM
