Slipping Clutch
I’m hoping someone can help me here.
I have a 88 F250 – 302 and had a new heavy duty clutch installed in 97 when the truck had 140,000 miles. I only use this truck for dump runs and plowing my driveway. Another words this clutch was hardly used. Since then, I put on less then 10,000miles.
Last winter I notice my clutch pedal was low. About 2 inchs from the floor but the clutch grabbed with no problems.
I check the fluid and it was low. I filled to top but the pedal was still low. I replace the Clutch master cylinder over this past weekend, bled the system and all was fine with the pedal. Now I noticed that the clutch grabbed almost to the top. Anyway, I went for a spin and now clutch is slipping in every gear. You have to drive slow in 1 or 2nd gear just to make it back.
Before I replaced the clutch MC, even though the pedal was low, the clutch grab with no problems. Don’t know what happened here.
I didn’t need to reset the spline because the MC rod aligned to the pin. It might have been a ¼ inch off but thought it was OK. I did everything the Haynes manusl described.
Why all of a sudden is my clutch slipping in all gears. Doesn’t make sense. Could it be I need to replace my clutch ? I hope someone can give me some advice here so I can get an idea what to do next.
Thanks for your time in advance and I’m looking forward to your advice.
Runner
If I don't put in the clutch while going into a gear, it will grind. When I put in the clutch pedal, all 5 gears go in with no problem. It's when I release the clutch pedal, it seems like the clutch is slipping bad. With the pedal all the way up, the engine will still idle. If I rev it will grab.
I'm thinking maybe it's the internal slave cylinder or somehow fluid go into the housing on to the clutch plate and making it slip.
I tried bleeding again but still the same. Again, If i rev the engine then the clutch will grab but not fully.
I give up.. If anyone has other suggestions, that would be great.
Oh well. Time to bring into the shop..
thanks,
Runner
I thought so.. I was just going through the Haynes manual.. Geezzz. What a job..
I'm guessing when I have a look, I will find out uh? Hope I can tell what bad and what's good..
Runner
thanks,
Runner
