you asked so here it is, with an additional "toy" i got as a birthday present from the kids. snap-on impact, and a harbor freight cordless grease gun. the only con of the grease gun i can see after 4 months of use is a small grease delivery per pump. with the lincoln in work, 8-9 pump cycles into a kingpin on one of the dump trucks and you are good. with this one it takes 15-20 cycles. but for home use it is fine.
geez how much greezing you doing?? a couple pumps each joint good for a year or so, seems like the battery would go bad from sitting, unless you work in a shop using it every day.
