Aerostar Ford Aerostar
15" tire swap
Old Jan 3, 2013 | 07:06 AM
62star's Avatar
62star
15" tire swap
Hi all,
I have a 92 Aerostar and i'm thinking about swapping out tires and rime with 15" alloys off a 98 Contour i'm parting out. The tires on the Contour are a lower profile tire, the total outside diamater is the same as the Aerostar 14" so clearance shouldn't be a problem. Is there any benefit or downfall to doing this ? The rims on the Contour look better and have newer tires on them. Any opinions would be greatly appreciated.
Old Jan 3, 2013 | 12:20 PM
KhanTyranitar's Avatar
KhanTyranitar
Yeah, first off the offset has to be correct, I was not aware that Contours used a 5 lug rim, but I haven't seen a Contour in a while. The tires off a contour are not weight rated to handle an Aerostar, so not only will your ride quality suck, but the tires won't last very long and aren't safe either.
You are better off running 15" rims off an Explorer and some slightly taller profile tires, like those listed on this forum. Thats what I elected to do, it looks better, the ride quality is improved, the road noise went down, and the weight handling capacity is improved.
Old Jan 3, 2013 | 12:29 PM
Car Guy's Avatar
Car Guy
The Contour wheels will NOT fit. The bolt patterns are completely different. As for the tires, the overall diameter is compatible but they will be like Khan said.
Old Jan 3, 2013 | 03:13 PM
62star's Avatar
62star
15" tires
thanks guys, that will save me a little work not changing tires. if you know anyone needing a 2.5 V6 or any contour parts let me know. thanks
Old Jan 3, 2013 | 09:00 PM
aerohiwaystar's Avatar
aerohiwaystar
I put 15" twisted stars on mine. I think they were off an Ernie Bauer Bronco. Polished them up. They look great!
Old Jan 4, 2013 | 12:35 PM
Pablo-UA's Avatar
Pablo-UA
Mustang rims fit too.
Old Jan 5, 2013 | 11:13 PM
Car Guy's Avatar
Car Guy
They sure do!!!
redrivergorge
Mar 2, 2011 08:07 PM
parkland
17
Jan 26, 2010 06:14 PM
35inchtires
Jul 13, 2003 08:25 PM
spencercj
1983 - 2012 Ranger & B-Series
Jun 4, 2003 07:52 AM
Big Red Bronco
1978 - 1996 Big Bronco
May 24, 2003 08:19 PM
