severe oil leaking HELP!!!
Old Jan 2, 2013 | 06:20 PM
ALPINE8181's Avatar
ALPINE8181
Unhappy severe oil leaking HELP!!!
ok 2 days ago i was reving engine to get up driveway in snow with no 4x4 yesterday on way home truck dies out in front of house,, starts and shuts off
today i put oil and it starts but pouring oil from under turbo drivers side i cant really see where its coming from i can see the icp it has oil on it but not sure if thats is the problem . it starts to pour out when cranking and when running.
what can i do or look for its cold out here ....
Old Jan 2, 2013 | 06:33 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Right under the turbo could be the turbo drain tube or the seal went on the HPOP cover.
Josh
tobytyler84's Avatar
tobytyler84
I had an 01 7.3 that did the same thing to me. I took it to a mech and he told me a bolt worked loose on the turbo. Only cost like 60 bucks to get it fixed. Don't know if its the same situation but sounds awful similar.
Old Jan 2, 2013 | 07:14 PM
ALPINE8181's Avatar
ALPINE8181
there is no oil on top its def coming from rear of engine i dont wannna pull more stuff off if i dont need to but its coming out fast.. i was reading about bed plate ? can that be seen ?
Old Jan 2, 2013 | 07:17 PM
Bullitt390's Avatar
Bullitt390
ICP sensor
Josh
Old Jan 2, 2013 | 07:20 PM
ALPINE8181's Avatar
ALPINE8181
i guess ill wrap the icp with a rag and see if it still leaks down im hoping thats it . and not the rear main oil seal
Old Jan 2, 2013 | 07:24 PM
Bullitt390's Avatar
Bullitt390
Remove the Y-pipe heat shield and look at the ICP from below.
Josh
BLADE35's Avatar
BLADE35
mOST REAR MAINS Oil leaks are simply owner Overfill or bell house Hanging drips
Old Jan 2, 2013 | 07:31 PM
ALPINE8181's Avatar
ALPINE8181
any instructionn or pics of the heat sheild ? how many bolts ? sizes thanks ill try tomorrow im wrking on it in driveway bad stuff man ..thanks
Old Jan 2, 2013 | 07:39 PM
BLADE35's Avatar
BLADE35
https://www.ford-trucks.com/forums/8...ml#post7693493
Think I used a Picks to unhook the Electrical sensor for a Look
On Edit Oh you wanted IPR??
Old Jan 2, 2013 | 07:49 PM
m-chan68's Avatar
m-chan68
Assuming we are working on a 2003 engine, the two small bolts that secure the shield to the HPOP cover are 10mm heads, and the one bolt securing it to the driver side cylinder head is 13mm.
Old Jan 6, 2013 | 04:20 PM
ALPINE8181's Avatar
ALPINE8181
hi im back its not the icp sensor its intact but from under the truck i see a sensor hanging that cracked off is their other sensors behind there ? that would leak alot of oil thanks for the help
Old Jan 6, 2013 | 04:24 PM
BLADE35's Avatar
BLADE35
look at pic in Post #8
on an 03 ICP and IPR Sit next to each other
the ICP is closest to firewall
Either one could leak ALOT and FAST REALLY FAST
so your saying it leaks out the IPR???
Can you see it leak when someone cranks the engine or runing???
Old Jan 6, 2013 | 04:35 PM
m-chan68's Avatar
m-chan68
An oil leak, leaking out under pressure the way you describe should be very easy to pinpoint. Have you looked further up top the engine? Oil pressure switch, turbo oil feed supply line, turbo oil drain tube, oil filter housing (cracked?), oil cooler filter adapter and oil cooler top cover/gasket are a few other sources that come to mind. Do you have a way of posting pics of where it's coming from by any chance?
Old Jan 6, 2013 | 04:41 PM
ALPINE8181's Avatar
ALPINE8181
i took alot apart today and it looks like its coming from that icp location but i see a sensor hanging that cracked off the peice is plastic thats hanging with clip still attached so i know its a sensor just cant find where it went. i cant see that ipr sensor maybe that it? do you have a pic and is it hard to reach
