hatch lock doesn't work with key
Old Jan 1, 2013 | 09:32 PM
3cv's Avatar
3cv
So I looked at an 03 Excursion tonight, has some of the usual suspects, but the rear hatch lock doesn't work at all, with the key or with the power locks. This anything other than a "replace its guts" type operation? I've done the foil thing with my F350, actually i cut pennies and replaced the piece with that, but this seems mechanical.
Old Jan 1, 2013 | 09:37 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Here you go, this ought to do it: Ford Truck Enthusiasts Forums - View Single Post - Excursion Forum Tech Folder
Old Jan 1, 2013 | 09:51 PM
3cv's Avatar
3cv
Ah the good ol "here is a post that is close" reply...
I read that before I posted but it didn't seem to match. Most of the thread talks about the usual tired power locks but the key still works. Even that single post you reference assumes the key will turn.
This thing may just plain be broken.
thanks
Old Jan 1, 2013 | 10:39 PM
Toreador_Diesel
Mine didn't work too well either with the key, but after the fix I did and spraying some PB Blaster in the lock itself, it works awesome now.
Old Jan 1, 2013 | 11:20 PM
EXv10's Avatar
EXv10
Mine never has worked with the key but the mechanism is free. Is there an easy way to tell if the key is actually the right one for it?
Old Jan 2, 2013 | 01:14 AM
Nsaan's Avatar
Nsaan
Mine didn't work with the key or the actuator, I repaired the motor replacing the thermistor and lubed up the assembly. The lock key assembly was rusted at the back, I disconnected the actuator to key lock rod and lubed it up with penetrating oil, then after it started moving I put it all back together I hit it all with some spray white lithium. That was 5 months ago and it has worked every time I have tried it since.
Old Jan 2, 2013 | 08:10 AM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
Same with mine, neither the key or the actuator worked. I replaced the actuator and the key still didn't work. I took the key assembley out and lubed it up real good, worked the key back and forth... Repeated about 50 times and reassembled. That did the trick to this day.
Old Jan 2, 2013 | 11:33 AM
3cv's Avatar
3cv
thanks everyone, looks like there may be hope
Old Jan 2, 2013 | 11:47 AM
cooperfamily's Avatar
cooperfamily
There's hope. Just did mine. Cleaned all the linkage, pins and parts then used PB Blaster to free it all up. Then sprayed the white lithium grease to it. The key cylinder I took out and is now soaking in the PB Blaster. When I put key in it doesn't feel like it is hitting any tumblers. I may have to look at a new key cylinder. BTW, don't let it soak in a plastic disposable cup. DON'T ASK.
Edit: the arm on the actuator was broken so I had to replace it too. Prob from trying to work and all the linkage was froze.
EXv10
Nov 8, 2013 10:30 AM
GamerGirlAlice
16
Sep 27, 2013 10:14 PM
Greywolf
All Things Towing
65
Jan 29, 2012 01:31 PM
Beau Bo
Sep 4, 2011 06:12 PM
Donald Rohret
1983 - 2012 Ranger & B-Series
Dec 14, 2003 08:08 PM
