clutch fork install advice needed
Old Jan 1, 2013 | 08:09 PM
MONAVIERONJON's Avatar
MONAVIERONJON
We just installed a brand new clutch and after it is all installed, drive shaft, crossmember, basically complete. then i notice that the clutch fork isn't sitting like it should. put into gear and the first time clutch pedal is pushed , the clutch fork pops out. Basically it wasn't in the throw out bearing groove so when the slave cylinder engages, it actually allow the clutch fork to go forward towards the flywheel. Is there a trick to get this bugger in there. I already played with it for about an hour. I just cant get it to sit properly in the groove for the throw out bearing, it is only able to in front of the groove near the plastic end........HELP...........SOS................HE to the LP!!!! thankx!!!!!!
Old Jan 1, 2013 | 08:37 PM
glovemeister's Avatar
glovemeister
Check here:
http://www.thedieselstop.com/faq/949...e=stjs73br.htm
BradBryan58
Apr 20, 2018 08:49 PM
Visseroth
Apr 28, 2013 07:29 PM
custom1106
13
Mar 18, 2011 07:17 PM
charlessocccer
34
Dec 15, 2010 03:17 PM
92F150XLT
Dec 8, 2005 09:00 PM
