new here + need easy help please
Old Jan 1, 2013 | 06:32 PM
1ton5four's Avatar
1ton5four
Question new here + need easy help please
Hi, new here & owner of a new (to me) 02' e350. Go me.
My suspension just got squeaky recently & I bear it when at low speeds + over speed bumps. I crawled under & noticed im missing 2 plastic or rubber or polyurethane FLAT bushing type things that have these nipple thinfs that come thru the hole in the leaf spring below it. These bushings are in between each leaf spring on my right side where as the left side has 1 remaining. What are these bushing pieces called? I looked up leaf spring bushings on the web & keep getting pics of more cylindrical bushings maybe for bolts & not what Im looking for.
Any help thank you.
Old Jan 1, 2013 | 07:35 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I don't think you can get those anymore, I may be wrong though. Your van must have a fair amount of miles for those to have worn out and fell out.
Old Jan 2, 2013 | 04:47 AM
JWA's Avatar
JWA
You might try contacting or visiting a local heavy truck spring/frame shop in your area. If IDI John is correct someone in the aftermarket will probably have exact replacements for those bushings.
Old Jan 2, 2013 | 01:32 PM
1ton5four's Avatar
1ton5four
Thanks. Im goin that rout now makin phone calls
Old Jan 2, 2013 | 11:14 PM
joshofalltrades's Avatar
joshofalltrades
as you're looking for the bushings, also ask WHY did they fail. persistent leaks of just about any fluid will cause various bushings to decompose
i suspect that someone will start marketing aftermarket bushings for your application one of these days - if you need them i'm sure others will too.
Old Jan 2, 2013 | 11:36 PM
YoGeorge's Avatar
YoGeorge
I believe they're called leaf spring "pads" and a quick Google search shows some apps available. Not sure what it'll take to get them for your specific springs--seems to me a leaf spring rebuilding kind of place would have these available on some basis.
Good luck,
George
Old Jan 3, 2013 | 10:09 AM
blageurt's Avatar
blageurt
Jack up the rear of the truck so both wheels are off the ground BUT the axle and springs Hang down ( you need to jack the frame ) ..then get some wheel grease or other grease with a gun and stuff it in the spaces...
green_95
16
Jun 4, 2016 08:38 PM
greatbargins10
Apr 15, 2012 06:39 PM
jgrim23
Jun 13, 2006 08:11 PM
dazedandconfused
Aug 2, 2004 06:10 PM
el conquistador
1983 - 2012 Ranger & B-Series
Jun 20, 2004 09:25 AM
