drivebelt tensioner arm - help
Happy New Year guys
As usual, one job turns into two... first job, replace the alternator
first step is to remove the drive belt - to do that you rotate the tensioner arm to relieve the tension on the belt. there is a square hole in the tensioner arm to accept a 1/2 in breaker bar. I'm goo to here.
Problem is that the 1/2 in hole has broken off (with no release of tension)
Any suggestions? How does one replace the drivebelt tensioner arm?
Thanks,
So annoyed...
Thanks,
So annoyed...
I think you just made my day. Thanks!
Not sure if you noticed, but to the right of the alternator, just down a little, there is a hole there that could take another idler pulley, but for some reason, Ford never installed one.
I took the bolt holding the pulley from my old tensioner and used it to put another idler pulley to the right of the alternator. I thought the previous owner had lost it so I installed another one. I didn't like the idea that the belt could dance too much there.
