Sponsored by: Real Truck
DTC code help
Old May 26, 2003 | 02:32 PM
dpicone's Avatar
dpicone
Question DTC code help
Anyone know what the heck this code means:
P1406 - Diff Pres Feedback Sens Downstream Hose Off/Plugged
Any help would be nice.
Old May 27, 2003 | 11:00 AM
dpicone's Avatar
dpicone
DTC code help
no one???????
Old May 27, 2003 | 11:37 AM
Waxy's Avatar
Waxy
DTC code help
Well I don't know for sure, usually I don't post unless I'm pretty confident in the answer. So here's an "educated" guess.
The rear differential has a vent hose on it that maintains atmospheric pressure in the diff. If this hose is plugged, it will cause pressure to build up in the diff that will eventually lead to seal failure. A plugged diff vent is the most common cause of seal failures.
I wasn't aware that this was computer monitored, put perhaps it is these days.
It should be fairly simple to track the small vent hose coming from the diff and check to see that it isn't plugged.
Good luck,
Waxy
Old May 29, 2003 | 09:48 AM
dpicone's Avatar
dpicone
DTC code help
the differential pressure sensor is part of the smog equipment and it is located under the hood. I wish someone was a Ford Mechanic here and could tell me how to fix it.
Old May 29, 2003 | 11:36 AM
rlh68050's Avatar
rlh68050
DTC code help
The DPFE sensor monitors the exhaust gas flow from the EGR valve back to the intake. This information is then fed back to the PCM. There are two hoses (an upstream and downstream) which plug into the sensor. The code that you are seeing is indicating that one of these hoses has come loose. The sensor is located near the EGR valve and the hoses are going to tubes which feed into the exhaust manifold. Take a look at the sensor and see if one of the hoses is off. If it is, fix it. If it is not, there could be something wrong with the sensor, replace the sensor. These are known go bad on a multitude of Ford vehicle lines. let me know if you need any help.
BTW, the reply about this having something to do with the axle differential was hillarious!!!. Sorry, but it was.
Old May 29, 2003 | 11:48 AM
Waxy's Avatar
Waxy
DTC code help
Well, thanks for enlightening us Rob.
I did say I was guessing.
I'll have to quit that.
Waxy
Old May 29, 2003 | 01:58 PM
rlh68050's Avatar
rlh68050
DTC code help
Waxy
Didn't mean to offend, but from my standpoint it was funny!!!.
Old May 29, 2003 | 08:50 PM
FortyFords's Avatar
FortyFords
DTC code help
Don't forget that the egr valve and its ports can become clogged with carbon build up and cause
insufficent flow also !
Just thought I'd add to the Hillarius nus !
Not really Waxy ! its a canadian thing!!!!!!!!
Rich
tlcsr66
May 14, 2014 04:08 PM
swunderle
Escape & Escape Hybrid
Nov 7, 2004 03:59 PM
mantta
Mar 29, 2002 05:42 PM
otto
Mar 17, 2001 04:21 PM
jowilker
Jan 8, 2001 12:54 PM
