block heater
Old Dec 30, 2012 | 10:31 PM
oasisbenk's Avatar
oasisbenk
block heater
My block heater worked yesterday, today it is tripping the breakers in my shop. Got any input?
Old Dec 30, 2012 | 11:09 PM
tappit01's Avatar
tappit01
check the plug on the front of the truck, i've burnt up a few of them over the years.
chris
Old Dec 31, 2012 | 12:08 AM
woodnthings's Avatar
woodnthings
Don't mess around with it. Block heaters have destroyed more than a few trucks. Since it is 115 volt and right at 1,000 watts, you need to correct it before using. Easiest way to determine what is going on is to disconnect the other end from the block heater on the oil filter housing. If it doesn't trip a breaker it is the heater. If it des, it is the cord.
Old Dec 31, 2012 | 07:23 AM
Tugly's Avatar
Tugly
This happened to me when I inadvertantly added more electrical load on the same circuit. Checking for anything extra on the circuit (yard light?) would be step 1, then do as woodnthings suggested. I had to buy a whole new block heater for Stinky and run the cable.
Old Dec 31, 2012 | 08:25 AM
ggirten's Avatar
ggirten
My nephew had one that was bad at the heater. It shorted out and burnt his truck completely up.
Old Dec 31, 2012 | 10:03 AM
tommyl's Avatar
tommyl
Can't wait for mine to short-out: need new truck!!!!!!!!
Old Jan 1, 2013 | 07:45 AM
oasisbenk's Avatar
oasisbenk
Thank guys, it is the only thing plugged in. Ill have to disconnect it from the oil filter housing and start there. Il let you know. On a side note it is 9°the at my place this morning and my truck is parked outside my shop.
Old Jan 1, 2013 | 08:52 AM
Tugly's Avatar
Tugly
Yea... the PNW is in the meat locker this week.
Old Jan 1, 2013 | 01:43 PM
KelVarnson's Avatar
KelVarnson
Is it tripping a breaker, or a GFI?
Old Jan 1, 2013 | 02:12 PM
kawcrasher's Avatar
kawcrasher
9 out 10 times it's the plug. But it is always best to pull the cord and check it. If it won't start on it own, I would change the plug and try that. If it works keep an eye on it for a few hours then fire it up. Then get her in the shop and pull and inspect the cord where it's warm.
Old Jan 2, 2013 | 12:04 AM
BobbyDiesel71's Avatar
BobbyDiesel71
how old is your GPR? I just replaced my GPR that was 7 years old
I can now start the truck w/o plugging in block heater
There is some thread here that will tell you how to test/diagnose a bad wire lead or actual heater element. search and you will find..
Old Jan 7, 2013 | 10:16 AM
Kaiman412's Avatar
Kaiman412
99% of the time it is NOT the block heater; it is the block heater cord. Double and triple check the cord for any kinks or indentations. Unplug it from the element and clean the ports and the brass outside tab (I used my wife's nail file for the outer tab, gently rubbing away debris). I unplugged mine and pulled the whole cord out and found a tiny kink was actually a break in continuity. Also the minimal corrosion on the connector didn't help. It was a 20 minute job (re-running wiring) but saved $. You can get replacement cord on amazon too for about $12-$16. Just make sure it's the right cord!!!!!
rocket_scientist
Dec 30, 2017 04:25 PM
mblayton
Ford Truck Parts for Sale
Jan 9, 2017 05:53 PM
Shu
Jan 13, 2016 07:14 PM
EXTREMEFUN1300
Dec 13, 2010 10:56 PM
bbull55
Feb 1, 2009 11:26 AM
