Sponsored by: Real Truck
Hubs? 4x4?
Old May 27, 2011 | 09:19 AM
openexcess's Avatar
openexcess
Hubs? 4x4?
OK so i bought the truck 2 weeks ago (Stock, supposely) found out it had an intake. I installed my Rough country 6 inch lift, rims and tires last week and all is GREAT. took it out to the mud yesterday for the first time and got stuck... only to find out that my hubs werent lockig in using the switch on the dash.. so i jump out in the mud.. take off my centercaps and find out that i have superwinch hubs and they werent locked.. so i lock them (EXTREMELY easy) and next thing you know she pulls out of the mud like it wasnt there. All in all ther eis no popping grinding etc.. the hubs are very easy to lock in. my questions are:
Q. Are the superwinch hubs still supposed to work with the ford vacuum lines, or do i have to manually get out and lock them?
Q. Is there any benefit from having the superwinch hubs rather than stock?
Old May 27, 2011 | 09:28 AM
jc8825's Avatar
jc8825
It is my understanding that no aftermarket hubs will work with the Ford ESOF. All aftermarkets will be manual, causing you to have to manually lock them. It much more reliable in the long term than the Ford hubs, just a hassle to some to have to exit the vehicle to get 4WD.
Old May 27, 2011 | 09:32 AM
openexcess's Avatar
openexcess
I know what you mean.. i seriously thought my truck was stuck and there was NO way my big *** truck should have been stuck in the little amount of mud with my tires LOL.. ill just have to remember to lock them in before i go play
Old May 27, 2011 | 09:34 AM
jc8825's Avatar
jc8825
Yeah, mine work (with the ESOF) periodically, to say that they lock with the ESOF switch, but to unlock them, I must get out and manually unlock them sometimes. I will probably switch to Warns eventually.
Old May 27, 2011 | 04:00 PM
mikesmayhem's Avatar
mikesmayhem
I have Warn hubs on mine and if I think I am going to need 4X4 I just leave the hubs locked. (no harm in doing so)When I need 4X4 I just use switch on the dash. My old FORD hubs would randomly work as well. Vacuum issue....
Old May 27, 2011 | 04:03 PM
jc8825's Avatar
jc8825
Nothing wrong with it, but if you turn tightly with the hubs locked in 2WD, they click.
Old May 27, 2011 | 04:08 PM
mikesmayhem
I've never noticed it with mine and I run with the hubs locked most of the winter. If the transfer case is also engaged and you are on dry ground that is not good and it can make some interesting noise.
Old May 27, 2011 | 04:13 PM
openexcess's Avatar
openexcess
So if i lock the hubs it will stay in 2wd until i engage it on the dash? or will it be in 4wd regardless of what the dash says
Old May 27, 2011 | 04:15 PM
mikesmayhem
It will be in 2 wheel drive until the switch on the dash is activated to provide power to the front axle. The front axle will spin because the hubs are locked but the transfer case will not be providing any power the front.....
Old May 27, 2011 | 04:40 PM
openexcess's Avatar
openexcess
Ahh I did no tknow this... will it hurt to just leave it locked? highway speeds and all
Old May 27, 2011 | 04:46 PM
mikesmayhem
I personally have not had any problems. I have run it down the freeway and on dirt and muddy areas when hunting and I have had no side effects of running with the hubs engaged an d the dash switch off. That being said, if I know I am not going to need it I do usually unlock them.I supposed it could reduce the gas mileage a little because of the extra friction but as you should know by now these trucks aren't designed for gas mileage. Good Luck and have a great memorial weekend. I am just heading out for a weekend of camping and have the TT loaded and ready to go!
Old May 27, 2011 | 10:42 PM
openexcess's Avatar
openexcess
Thank you for all of the Help.. its amazing how much you can learn on this forum. Have fun on your camping trip and be safe.
kipdog
Modular V10 (6.8l)
Dec 16, 2010 02:08 PM
rg200amp
Dec 13, 2007 09:50 AM
countryboy4_1qt
Jan 31, 2007 04:35 PM
Draft_Horse
Nov 29, 2006 08:49 AM
MacWizard
Feb 2, 2000 05:45 PM
