volare question
Old Dec 29, 2012 | 11:35 PM
lorts's Avatar
lorts
volare question
Would anyone know if there is any rotors with a 5x5 bolt pattern that would fit a volare front end?
Old Dec 30, 2012 | 08:47 PM
raerjim's Avatar
raerjim
Volare is 5x4.5 so an adapter would be needed.
Old Dec 30, 2012 | 09:14 PM
53FOPAR's Avatar
53FOPAR
Here's some:
2 Pcs 1 25" 5x4 5 to 5x5 1 2" x 20 Studs Wheel Spacers Adapters | eBay
Old Dec 31, 2012 | 06:58 AM
jniolon's Avatar
jniolon
old and in the way
keep in mind that if you use the spacers you're adding width to your track... make sure you have clearance at fender lip for the additional width.
you can also find a 'wheel shop' that can re-drill yours. They merely weld up the old holes and re-drill on the bolt circle you want. I've had rear axles done at Moser's and it worked fine...
check or ask around locally
john
Old Dec 31, 2012 | 06:16 PM
CharlieLed's Avatar
CharlieLed
Do yourself a favor and buy new wheels...
Old Jan 1, 2013 | 12:00 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Like Charlie said get new wheels and have the axles drilled for the 5x4.5 pattern. That was what I did on the old rear end.
proford1
Jul 21, 2009 07:44 AM
fivfivf100
19
Aug 2, 2007 09:18 AM
54fever
Oct 2, 2006 07:13 PM
brett
Nov 28, 1999 08:44 PM
