Rearend Question
Old Oct 2, 2006 | 05:41 PM
54fever's Avatar
54fever
Question Rearend Question
Hey guys,
Getting ready to drop off my truck rear to a local guy for sand blasting but have a question about it first. The rear is a 72 ford truck 9" 5.5" bolt pattern my question is can i have the axles redrilled to 4.5" bolt pattern or should i buy a different rear. I am ordering my polished stainless steel 4 link this week from tci and want to make sure i can redrill the axles before i go and weld the 4 link brackets to it.
Thanks Fever
Old Oct 2, 2006 | 06:22 PM
AXracer's Avatar
AXracer
not likely, but you could have custom axles made for ~ the same price a machine shop would charge to redrill with any bolt pattern and center hub size you desire. Don't forget tho that you'll need the right size brake drums to match.
Old Oct 2, 2006 | 07:08 PM
spiritrider1100's Avatar
spiritrider1100
Here is another avenue you might want to check from another post and questions
https://www.ford-trucks.com/forums/5...le-debate.html
Old Oct 2, 2006 | 07:13 PM
truckfarmer's Avatar
truckfarmer
I have had a couple of sets of axles redrilled to a 4 1/2" pattern. The machinist will press out the old lug studs and weld the holes shut. He then drills the flange with the desired bolt pattern. He asks that I bring the correct new studs so he can drill the right size holes. He did a pair for my son's dailly driver about 5 years ago and we have never had any problems with them.
