Ignition Actuator Replacement
Old Aug 20, 2002 | 09:03 AM
kmgplus3's Avatar
kmgplus3
I've seen on several threads that I can replace the ignigtion actuator to solve the problem of the ignition/key not returning to the run position after starting. I called the dealer about getting the part (no problem -$10) but he said that I have to pull the steering wheel and disconnect the SRS to do this. Has anyone done an actuator replacement on a 95 F 150? I was hoping to just pull the bottom off the tilt steering column and do it from there, but I don't want to mess with the air bag. Any advice?
Old Aug 20, 2002 | 10:31 PM
nitro94's Avatar
nitro94
This job reguires pulling the steering wheel and the pivot pins (2 special tools) plus most of the tilt wheel assembly.
Old Aug 21, 2002 | 07:47 AM
kmgplus3's Avatar
kmgplus3
Thanks, I'll take it in - another $100 bill to replace a $10 part.
Old Aug 21, 2002 | 10:05 AM
8996EBBroncos's Avatar
8996EBBroncos
shotgun64
Aug 26, 2015 05:14 AM
triskadek
May 24, 2014 12:52 PM
imjwm
Nov 9, 2013 01:40 AM
weavemaster
Nov 22, 2004 07:31 AM
