1978 - 1996 Big Bronco
Wiggle-Waggle
Old May 26, 2003 | 08:38 AM
bulldog288's Avatar
bulldog288
Wiggle-Waggle
My wife's 93 EB 5.0 has a wiggle problem at low speed. I actually sat in the middle of the road and watched the truck wobble from side to side. I checked the drag link and there is a very slight amount of play at the joint where it connects to the Pitman arm. I had her turn the steering wheel ever so slightly and response to the wheels was immediate. Any ideas?
Old May 26, 2003 | 11:03 AM
bigric's Avatar
bigric
Wiggle-Waggle
Have you checked for separated tires? Lift each tire up, then spin it; you're looking for a bubble or raised area in the tread. If you see this on any of the tires, get the tire replaced immediately. The next thing that will happen is that the tread will peel off, most likely on the highway.
94GreenTruck
Jul 25, 2014 01:53 PM
fatboyjon
Jun 12, 2010 12:06 AM
fkaster01
15
Apr 26, 2009 12:38 AM
fixxxer-upper
Aug 19, 2008 09:05 PM
reamer
Jan 31, 2005 08:28 AM
