Transmission Fluid
Old Dec 27, 2012 | 10:14 PM
lowtrkn2k's Avatar
lowtrkn2k
Question Transmission Fluid
I need a little advice on a transmission I just installed in my truck. When it was pulled as an engine/trany combo a lot of fluid spilled out of the tail and between pulling it, getting it to my house, and installing it in my 54 f100 I assume the rest of the fluid eventually spilled out the tail shaft.
Now I want to run the engine but the question I have do I just need to fill the transmission normally or will I need to also fill the torque converter separately? Will filling the transmission also fill the converter? I won't be driving the truck (still under construction) for a while. Also can I just cap the transmission lines since they aren't connected to a cooler.
Also I don't have a drive shaft installed so will the fluid leak out the tail?
Thanks for any advice
Last edited by lowtrkn2k; Dec 27, 2012 at 10:22 PM. Reason: added extra information
Old Dec 28, 2012 | 12:52 AM
xlt4wd90's Avatar
xlt4wd90
If you leave the transmission in park or neutral, you should not have to install any fluid for engine tests. If you do put any fluid into it, you will have to hook up all the lines, as the pump will run with the engine, and pump fluid through everything, including the cooling lines. And yes, if you don't seal up the tail shaft, fluid will leak out there.
Old Dec 28, 2012 | 07:53 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's good advice if you don't mind destroying the transmission. Running a transmission without fluid is just as bad as running the engine without oil. It doesn't matter if the trans is in park or neutral, no fluid means you'll need a new transmission. The pump is spinning anytime the engine is running. It has no sense of humor about running without fluid.
You will need the lines connected. For a temporary fix you could just run a line from one to the other. The trans won't need cooling running like that. You will need a plug in the output shaft. Either the driveshaft yoke or a plastic plug.
Old Dec 28, 2012 | 12:49 PM
xlt4wd90's Avatar
xlt4wd90
Sorry, I didn't think the front pump would have such tight clearances.
Old Dec 28, 2012 | 01:53 PM
lowtrkn2k's Avatar
lowtrkn2k
Ok thanks for the good advice. Do I need to do anything special with the torque converter or do you think most of the fluid is still there?
Old Dec 28, 2012 | 05:38 PM
stuart1's Avatar
stuart1
Install a yoke, connect the cooler, add fluid, fire it up in Park.
Add more fluid until the stick reads full. The convertor will fill itself.
Old Dec 28, 2012 | 07:15 PM
lowtrkn2k's Avatar
lowtrkn2k
Ok got it. I've always been a standard guy until my current truck which is new so never have to mess with the auto tranny. Many Thanks for the advice!!!
pablocruz69
Jun 2, 2011 11:53 AM
DBGrif91
Apr 23, 2011 08:24 PM
TexasDiesel97
Jan 15, 2009 10:36 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 11, 2008 08:38 AM
Joe Finn
1997 - 2003 F150
Jan 29, 2004 09:28 PM
