Brake Problem
Old Dec 27, 2012 | 01:30 PM
Brian0445's Avatar
Brian0445
Brake Problem
Today during the snow storm while plowing the brakes on my 99 F-350 with 7.3 seem to be haning up. The pedal seems harder than usual, after applying the brakes they dont seem to want to release. I also hear a clicking sound near the brake pedal. All the brakes seemed hot but the front left rotor was almost red hot with smoke. I stopped for a break at that point to let the brakes cool, and it was a little better but still seems like they are "dragging" a little. I am going to replace the LF caliper to see if that is the issue, wondering if it could possilbly be the master cylinder also. Any help would be great, Thanks!
<!-- / message -->
Old Dec 27, 2012 | 01:59 PM
howellt39's Avatar
howellt39
Definitely check the centering pins if it's been a while since they were last greased.
Red hot rotor would point to that first unless something was stuck in the pads.
Old Dec 28, 2012 | 02:01 PM
BillyBob69's Avatar
BillyBob69
What Howellt39 said. I would check the slide pins to make sure they are not seized up. this can cause the caliper to not move correctly and bind possibly causing one or both pads to drag.
Old Dec 28, 2012 | 04:39 PM
429 f-100's Avatar
429 f-100
X3 ON THE PINS
Old Dec 28, 2012 | 09:37 PM
PaysonPSD's Avatar
PaysonPSD
Guzzle's Caliper Slide Pin Lube
Old Dec 29, 2012 | 05:34 AM
Tugly's Avatar
Tugly
Oh... I know this one... all of the above! I had a slide pin issue (without my knowledge, obviously) and the caliper siezed up the first time I towed my boat downhill to a stop sign (intense braking). Not knowing how the boat would tow, I just thought "Hmmm... not as powerful as I thought" and drove on... dum-dee-dum-dee-dum.
Pulling into the driveway, my very observant wife noticed all the smoke pouring out of the left rear wheel. Uh... I think I have a problem. Removing everything for inspection... I had a damaged rotor, the caliper was cooked, the pads were... well... crystallized, and the parking brake was more rust than brake.
I started over.
Old Feb 6, 2013 | 11:09 AM
BWST's Avatar
BWST
Got Data?
Tugly, what brand rotors and pads did you choose here, and now that you've run these a while, how do you like them?
Melendez7.3
18
Sep 4, 2015 01:10 PM
silverking00
Apr 17, 2011 11:16 PM
texasjack
16
Nov 8, 2010 07:54 PM
7.34me
Oct 23, 2006 07:40 PM
Kris_Ranger
1983 - 2012 Ranger & B-Series
Sep 9, 2002 07:37 PM
