what sensor is this?help please
Old Dec 27, 2012 | 12:50 PM
cmdk_93's Avatar
cmdk_93
What is the sensor that is between the distributor and coil pack on tge side of the block on 300 l6 efi?what does it do?can it leak oil? Mine is broke and dont know what it is or does.
Thanks
Old Dec 27, 2012 | 08:42 PM
6978sghfbjklgdfsjhkl's Avatar
I'm pretty sure it's a knock sensor..4 use in the EFI system..if ur runnin' a carb non EFi--it may be unused..
I just had a 90's EFI block re-man'd..it had one...haven't looked at the hole since I got the block back..I think it's not connected to a galley of any kind.. take a close look at it..
Old Dec 27, 2012 | 09:52 PM
cmdk_93's Avatar
cmdk_93
Ok ill do some research thanks
Old Dec 28, 2012 | 01:18 AM
Yaga1973's Avatar
Yaga1973
Elder User - What???
Sounds like the knock sensor to me. To the best of my knowledge it won't leak any oil. I know that on some engines, depending on the manufacturer, the knock sensor did screw into the coolant jacket and this was only because knock sensors need to be close to the cylinder walls. However, I don't think the knock sensor on our 4.9's screw into the water jacket. I could be wrong, though, and I'll find out soon enough as I'm contemplating replacing mine.
If you beat us to it, let us know what you find out.
Old Dec 28, 2012 | 01:48 PM
cmdk_93's Avatar
cmdk_93
Yeah will do for sure.there is an oil leak im trying to trace down but might as well replace it while im in there.thanks for the answer guys
Old Dec 30, 2012 | 07:15 PM
HardkaseDaddy's Avatar
HardkaseDaddy
The oil sending unit is a common place for an oil leak on these blocks.
smle
Jun 15, 2015 11:38 AM
NittanySkydiver
Feb 15, 2008 01:43 PM
mrit
Sep 10, 2003 05:26 PM
tomph
Aug 22, 2003 04:33 PM
