cabs
Old Dec 30, 2012 | 02:49 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Narrow (33 1/2") rear frame rails are behind the cab: 1973/77 F250 4WD (High Boys) / 1973/79 F350's on the 140" wheelbase.
ALL other 1973/79 F100/350's have wide (37 1/2") rear frame rails behind the cab.
Wrong. The longbed 2wd crewcabs had the narrow frame rails. Also some of the f-350 cab and chassis trucks with the 133" wb had the narrow frame rails.
Old Dec 30, 2012 | 03:00 PM
crazyredneckanyhow
if you put a supercab or crewcab on a reg cab frame youll either need to raise a section of the floor behind the front seat or use a 2" body lift. Also as far as the f-700 goes the cab mounts are different.
Old Dec 30, 2012 | 03:25 PM
pha7env's Avatar
pha7env
reply to body mount differential
Modifying body mounts should not be a hurdle if i go that route. What about adding 4wd to the 700? In your opinion, would that be easier? I can either buy the cab or the entire flatbed rig. Price will be about the same. Thanks for the input. Robert
Old Dec 30, 2012 | 04:33 PM
crazyredneckanyhow
That truck should have leaf spring front suspension so i wouldnt think it would be to bad to install a solid axle. With the weight however youd need to have a dana 60 front. Check the spring pad width on the front of the truck and see how wide it is. That may make things easier to figure out.
Old Dec 30, 2012 | 09:46 PM
pha7env's Avatar
pha7env
D60 under 700
I will check asap. I've not bought the truck yet, although i have it locked if i want it. Wonder how much heavier the frame on a 700 is than a 350? Thanks for the suggestion, This gentleman that has the truck probably has 300 fords in a graveyard. The neat thing out here is that vehicles hardly rust, so they just sit and fade. He restores about 3 a year, mostly cars. When i went, i did not have much time. i will take more this time. I have a 205 case, and a HD44R with dynatrac arms, hardened axles, tubes tubes stripped,cleaned and ready for pads. I know it is not as heavy as i would like, and i will search for a 60, but worst case, the 44 will probably suffice being this will be a highway and dirt road truck running ~35s so, if we reinforce the tubes and chunk, it should suffice. Thanks!
gcooter
Nov 11, 2016 10:43 PM
projectdagger
Jul 3, 2011 11:56 PM
RJB1
Sep 7, 2007 01:26 AM
spitfyre
Jul 13, 2005 11:59 AM
RicksF100
Feb 8, 2005 09:26 AM
