Sponsored by: Auxito
Experts advice in this codes Help!!
Old Dec 27, 2012 | 10:26 AM
jorge995's Avatar
jorge995
1997 f250 LD 5.4 L with 150 000
Few days back i noticed my truck was misfiring with the cheap gas but it seem to run smother the high octane gas 93 so I decided to take it autozone for codes check ( NO CHECK ENGINE LIGHT ON BUT I CAN FEEL IS MISFIRING IS PROBABLY A COIL BECAUSE ONCE OR TWICE HAS DONE THE JERKING AROUND 30-40 MPH SO THAT IS NOT WHAT IM CONCERNED ) back to the codes I got
P1136 AND P0133
now for the p0133 it has to do with a 02 sensor in bank 1 but it also says ( fuel system is running rich or lean-check other codes first ) my truck has now high octane gas....... I was thinking since the truck has a light misfire some gas might be coming down and having the sensor throw a code or is it a bad sensor ?? and if it is the sensor which side is it ???
now for the P1136 I will have to do some research and hear from you guys what you think thank you in advance
Old Dec 27, 2012 | 12:32 PM
Bluegrass 7's Avatar
Bluegrass 7
133 Code is passenger side front sensor 1-1.
If the sensor is old, I would change it.
The code tells you the senor is being lazy on switching for some reason.
It could be contamination, an air leak in the exhaust, an inlet air leak etc.
The 1136 says contol box fan circuit.
Your right in the window of needing to get all these things fixed in order to clear all the issues you are seeing.
Good luck.
Old Dec 27, 2012 | 12:50 PM
jorge995's Avatar
jorge995
Ok I will replace the sensor and we will go from there ....
Question what is the control box fan circuit and where is it located and what should it look for ??
thank you bluegrass
Old Dec 27, 2012 | 01:07 PM
Bluegrass 7
I would get the 133 code first then clear the codes and see what comes back.
The 1136 may not come back.
Don't think it's applicable to your truck unless you have some special build.
Sometimes a combination of certain issues set other codes.
Within the program are some 1000 + codes not all of which apply to every build because the same program family is used for many different car and truck applications but with different applications made active and many not active.
For instance a F350 or 450 with a 5.4 used in a Line truck needs a remote high idle function to operate the hydraulic boom that a pick up doesn't need.
How that is acomplished is a switch signals the program to use a different idle speed table value and opens the IAC to get the motor speed to match it..
Good luck.
Old Dec 27, 2012 | 01:09 PM
jorge995's Avatar
jorge995
Ok will be back with results thanks again
Old Jan 1, 2013 | 12:34 PM
jorge995's Avatar
jorge995
RESULTS HERE
Ok I said will be back so here I am the code for the oxygen sensor and the circuit box malfunction are gone ( O2 sensors replaced )
As for the misfire I thought it was a coil or a plug but it is not... coils has been replaced and plugs has been replaced ( motorcraft ) and tried unpluging each coil but the misfire is so light that when I unplug a coil the shaking is twice as a much so maybe an injector the truck has 125xxx miles maybe valve ?????? or a sensor somewhere ????? EGR valve all vaccum hoses checks out even the pcv valve and 90 degree angle that connects to the back of the intake is famous for causing misfire like effects I dont have a friend to go to that has a computer that reads mode 6 ..... I went to autozone and no codes are pending
this misfire is on whenever engine is cold or hot 93 or 87 octane gas whenever I go over 1500 - 1800 rpms the misfire is gone it doesn't matter the speed is only whenever the rpms are in that range
Any toughs would be helpful thank you
Old Jan 1, 2013 | 12:38 PM
vfast's Avatar
vfast
are you on the same tank of gas? put in a bottle of gas drier and run it out then refuel...
Old Jan 1, 2013 | 12:52 PM
jorge995's Avatar
jorge995
yes man I'm in the same gas tank and its full i put in an injector cleaning lucas one will try gas drier after to see thanks for reply
Old Jan 1, 2013 | 12:55 PM
vfast's Avatar
vfast
sounds like you got a little water in your fuel
Old Jan 1, 2013 | 01:01 PM
jorge995's Avatar
jorge995
Where could this water be coming from ?? I live in South Florida climax is very hot down here also when bought the truck I took the tank down and cleaned really good and changed the gas filter
Old Jan 1, 2013 | 01:05 PM
vfast's Avatar
vfast
rain...from the gas station holding tank..
Old Jan 1, 2013 | 01:34 PM
MBDiagMan's Avatar
MBDiagMan
Yes there are many ways for water to get into the fuel. Burn the tank as dry as you dare and refill. I am not familiar with the additive you mentioned. I know that B12 does a great job for emulsifying the water and burning it.
Best of luck with it and keep us posted.
Old Jan 1, 2013 | 01:55 PM
jorge995's Avatar
jorge995
ok thank you guys will try that and how it goes will let you know any results
needshave
Jul 31, 2019 02:46 PM
TrueBlue02
Nov 16, 2015 05:07 PM
Suhaj213
1997 - 2003 F150
Jun 7, 2013 11:52 PM
ford2go
General Automotive Discussion
Jan 21, 2008 09:37 AM
Tim Halliday
May 18, 2004 05:46 PM
