4 wheel drive not working
Old Dec 26, 2012 | 08:20 PM
rougerocco's Avatar
rougerocco
My 4 wheel drive in not working, we got some snow today. And it doesn't seem to be working. Rear end is sliding around like it is in 2 wheel drive. I have after market Warn Hubs (have been on for a few years). And idea how to trouble shoot this? Light on the dash comes on too.
Old Dec 26, 2012 | 08:26 PM
Sparky04SD's Avatar
Sparky04SD
I would suspect one of your hubs isn't engaging. If you can, put the truck in 2WD and crawl under it and attempt to turn the front drive shaft. If it turns, replace hubs. If it doesn't then you'll need to find out why the transfer case isn't kicking into 4WD. You can also attempt to put the transfer case into 4WD low range and see if it shifts OK. If it does and your drive shaft test was positive then you're in 4WD and the sliding around is some other problem.
Hvymtlc5
Jun 4, 2015 06:09 AM
mesnipe
Jan 10, 2015 11:40 AM
jerryspoolman
Oct 6, 2010 02:26 PM
fomocojake1
Aug 15, 2007 11:07 PM
tobetaxfree
Feb 11, 2003 07:27 PM
