Hard Starting
Old Dec 22, 2012 | 08:36 AM
Nabors's Avatar
Nabors
Hard Starting
Hey guys,
I've got a 2000 f250 with the 7.3 and, even in 50* weather, it takes at least a minute of cranking to start. I've heard about watching the electrical meter to the left of the speedometer and I noticed that there is no change to it from when I turn the ignition on. Isn't it supposed to be a little low then pop back to normal when the relay turns off? I'm getting a new fuel filter and air filter soon but I suspect that it is the relay. Also, it blows a lot of white smoke when cranking and for a few minutes until it gets warmed up. Thanks!
Old Dec 22, 2012 | 09:10 AM
nlemerise's Avatar
nlemerise
Sure sounds like the Glow Plug Relay (GPR) or glow plugs (GP's) or both. Take a screwdriver and jump the two large posts on the GPR for about a minute with the key on, but not started (KOEO). If it starts right up, you have to replace the GPR...to test the GP's you need a multimeter to check their resistance (ohms). That white smoke you are getting is unburned fuel...give away the the GP's/GPR aren't doing their job. How long are you leaving the key in the on position before trying to start your truck?
Here is a thread with lots of cold, hard start issues...
Old Dec 22, 2012 | 12:24 PM
Nabors's Avatar
Nabors
Thanks for the response! Sometimes it's 30 seconds and sometimes I try to cycle it for a minute a few times. Once it gets started and warmed up a few minutes I can start it no problem. I'll do the test you stated and let you know how it goes.
Old Dec 22, 2012 | 04:08 PM
nlemerise's Avatar
nlemerise
I'm betting the GPR is toast...
Old Dec 26, 2012 | 09:21 PM
Nabors's Avatar
Nabors
I put in my 6637 filter and new fuel filter and, in the cooler weather this morning, she started right up. No multiple cycles. Thanks!
Tact
15
Dec 24, 2013 03:56 PM
Bird Hunter
Jan 2, 2010 07:14 PM
poorfatkid
Nov 8, 2007 11:35 AM
live2hunt
Aug 18, 2005 07:15 PM
LOOKBOY
Jul 7, 2005 07:31 PM
