C6 QUESTION
Old Dec 27, 2012 | 03:33 PM
RAY1986F150's Avatar
RAY1986F150
Originally Posted by Gary Lewis
Don't forget Brandon/Bruno's friend James if you have one rebuilt. He's done two diff's, a transfer case, and a driveshaft for me and I'm happy.
I probably won't get it done until after I move back to Kentucky. I have too many things to do before then. Baby #2 is due in 3 weeks!!
Old Dec 27, 2012 | 05:08 PM
Gary Lewis's Avatar
Gary Lewis
Oh yes! I forgot, but I'll bet you haven't.
Old Dec 27, 2012 | 06:25 PM
Franklin2's Avatar
Franklin2
I would actually test it out first and see if it really does have a lot of play in the rearend(did you and I missed it?). What if your u-bolts that hold the rear axle to the springs are loose? The bushings in the leaf springs ok?
Old Dec 27, 2012 | 07:08 PM
RAY1986F150
I haven't tested it yet. At a glance the bushings don't look bad, but then again neither did the front TTB axle pivot bushings until Gary and I got them axles pulled down and realized the inner sleeve was riding on the the outer sleeve!! I know the u-bolts are tight I checked them a couple times right after I swapped the axle in. I was afraid they would settle somehow and come loose. I will run outside in a litle bit and check out those bushings a little closer.
collinrandle
13
Oct 20, 2015 05:40 PM
Boba Fett
Dec 26, 2013 08:07 PM
TonyJestis
15
Nov 5, 2012 06:13 PM
notyettoday
Feb 8, 2007 01:55 PM
1978fordf250
Dec 15, 2006 04:49 AM
