Heater Hose Support Bracket?
Old Jan 15, 2013 | 11:58 PM
  #46
ReBilld's Avatar
ReBilld
My truck is running. I drive it every day. I still have the rough idle and not running the best, but I'm hoping to do Stage I injectors and T500 soon. I hope that will fix my problem. I got Mike's TS chip too, so if the injectors fix the problem, I'll be getting some tunes too
Old Jan 16, 2013 | 02:41 AM
  #47
stainlessstroker95's Avatar
stainlessstroker95
Dang Bill they should of done that from factory. That looks better than the ideas in my head.
Old Jan 16, 2013 | 07:52 AM
  #48
fordman67's Avatar
fordman67
Ahh,i didnt know if you were still driving.aka how bad it was.hope ya get the parts soon.
Old Jan 19, 2013 | 07:48 AM
  #49
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Here's my solution:
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Jan 19, 2013 | 08:42 AM
  #50
ReBilld's Avatar
ReBilld
Originally Posted by DZL JIM
Here's my solution:
That looks a lot better than mine for sure! I have access to CNC machines at work, but I don't know how to run them! LOL!! And, there is nobody there to show me. All those machines just sitting up there doing nothing.
Old Jan 19, 2013 | 03:49 PM
  #51
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I had not made chips in a while and had the itch to do some crankinig on the old Bridgeport, so I'm kind of glad this post came up.
If there's any interest in these I will gladly consult with my machinist to produce more.
__________________
Old Jan 21, 2013 | 12:10 PM
  #52
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Here's my solution:
Looks fine, but honestly it needs some insulation between metal and rubber hose, and I like more the one from Bill, more practical, more economic, easy to fab, etc, etc. Sorry, but just IMHO.
Old Jan 25, 2013 | 02:08 AM
  #53
Spktyr's Avatar
Spktyr
Well, this arrived in the mail today:
I like it quite a lot, seems like something a more-talented-than-usual Ford engineer would have come up with. It appears to be quite sturdy and while you wouldn't want to use it as a lifting point, it's at least as solid as lifting eyes I've seen on some truck engines in the past. It looks like something one would expect to see in the engine bay, really. The only suggestion I have would be to use a little bit of black Plasti-Dip to hide the tips at the top where the heat shrink inevitably pulled away - but that's just a cosmetic thing, not functional.
Maybe you should consider taking orders for a batch of these? Thanks for sending me this one - I appreciate it.
Here's my solution:
That looks really neat - would make a great trick show piece for a heavily (and obviously) modded engine where there's a ton of non-stock stuff clearly in view. My concern with it would be the chamfer where the hose goes through - it seems like it might damage the hose in use. Obviously easy enough to fix. Needs to be anodized or cad plated some odd color and have your company logo on it, too.
Old Jan 25, 2013 | 07:47 AM
  #54
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
By design I didn't want to rely on any insulation in there. I made it such that the hole is sized so that the top piece of the support clamps down firmly onto the hose so that the hose cannot move at all, yet it is not really crimping the hose at all. Upon install, I dictate the bend coming off the top of the pump and clamp down, then the rest of the hose going to the heater box can give and flex, and not rub anywhere on the support bracket.
Anyhoo, that's my opinion of how it should be done.
Bill's bracket looks great and is a great guide for anyone that wants to build their own.
__________________
Old Jan 25, 2013 | 04:15 PM
  #55
ReBilld's Avatar
ReBilld
Glad you liked it Spktyr! I have Plasti Dip, and thought about using it, but I didn't know if I could get it as thick as that shrink tube.
Old Jan 25, 2013 | 07:19 PM
  #56
Spktyr's Avatar
Spktyr
I would keep the shrink tube for sure, just add a little PD at the top edge where the tube ends to look more 'finished.'
Old Feb 25, 2013 | 12:26 AM
  #57
Spktyr's Avatar
Spktyr
Finally got a chance to install the ReBilld bracket on my truck.
What was left of the Ford original piece:
And the ReBilld bracket:
A couple of further suggestions - shorten the vertical part of the bracket by about a half inch, but only move the holes for the clamping bolts down about 1/4 inch. This would provide additional hood clearance (it's kind of close on my truck). Also, extend the short part of the bracket rearward by about 1/2 inch (you could do both at once by changing the point at which you bend it) to allow for socket access to the alternator bolt with the clamp bolts in place.
Works well and looks good, though.
Old Feb 25, 2013 | 01:38 AM
  #58
richdawg's Avatar
richdawg
Thanks for the feedback on the bracket, it looks good and should last much longer than the original.
I was noticing there seems to be another option, and that would be changing water pump to the IH type. I noticed the engine pictures Glenn (oldbird1965) has posted does not show a hose there at all, so it must be rerouted on the IH water pump.
Old Feb 25, 2013 | 10:27 AM
  #59
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Rich, good catch there. I havent noticed .
Old Jul 8, 2025 | 01:14 PM
  #60
Wyo Bill's Avatar
Wyo Bill
8th Gear
Hi! Just found this thread and was wondering if you did in fact make some of these brackets. I have a Ford 1997 F350 7.3L Diesel . Bracket is broke! Thanks for any help. Bill from WYO
