HPOP Test?
Old Dec 24, 2012 | 07:16 PM
JethroF250's Avatar
JethroF250
HPOP Test?
hey guys what is the procedure to test and determine the output pressure of the hpop and to determine if there are any leaks? thanks
Old Dec 24, 2012 | 08:15 PM
Yahiko's Avatar
Yahiko
Look in the tech folder for AIR TEST
Your going to need an adaptor and some beer because the older ICP sensor
is a PITA to reach. Also if you can get your hands on a IPR control box
to trigger it. That will make you life easier. Maybe you'll get lucky and
it a dirty screen in the ICP sensor.
What's going on that you think it a HPOP leak ? Some one any know
what it is.
Sean
Old Dec 25, 2012 | 07:03 AM
JethroF250's Avatar
JethroF250
poor or no throttle response, low power, restriction on rpm. almost seems like the damn thing dont wanna do nothing until it gets enough oil pressure to the injectors to make her go
Old Dec 25, 2012 | 02:34 PM
mustang_309's Avatar
mustang_309
Do you have a scan gauge II or something that will read live data? Being able to compare ICP pressure and IPR % should tell you if you have a HPO leak, or if the HPOP isn't putting out like it should.
Old Dec 26, 2012 | 04:59 PM
JethroF250's Avatar
JethroF250
yep. truck started messing up after it warmed up. ICP was running between 960 and 1000 at idle in park, idle in drive with a miss, and idle in drive at 99% throttle and no throttle response. during these same conditions IPR% was between 19.0 and 20.7
westandr
Jul 13, 2018 01:25 AM
Dukhunt22
Dec 10, 2013 10:49 PM
steventothemax
May 13, 2012 10:46 AM
4x4countryboy
Mar 17, 2012 05:50 PM
suds
Sep 11, 2010 11:56 AM
