When in 4wd it pulls to right upon hittin gas and when turn it pops on drivers side, maybe lockout hub bad? Took it apart appears good alot grease they r m&m, ?
Seems to be, no constant noise just occasional pop, then pulls to right when hit gas, i jacked up driver wheel it wontcspin back butvdoes forward so i turned **** to unlock then back to lockcand then wheel locked in, took for drivecpops again n back to pullin to right
That's your wheel bearing lock nut that you're talking about. You're spindle bearing is a needle bearing inside the spindle that supports your outer axle shaft.
I don't think that is possible but those spindle bearings will do some really unpredictable stuff when gone bad. a loose axle shaft is normal, but if too loose that is bad. I would sure look into those spindle bearings. You had the hub off, now take the 2 nuts behind the hub off, to get the bearing hub off the caliper must first be removed, then take the bearing hub off the spindle, then take the 5 nuts off holding the spindle on and remove the spindle. there is a bearing and a 3 part seal in there if yours is missing any of this, look for a new one.
