bell housing question
Old Dec 24, 2012 | 04:02 PM
carlyoung's Avatar
carlyoung
my 83 F350 currently has a 351m in it. I am considering swapping in a 460. Will the bell housings match?
Old Dec 24, 2012 | 04:57 PM
4x484150's Avatar
4x484150
Yes, they have the same pattern. I'm not sure if the clutch will be the same or not. I have a Windsor engine, thats why.
Old Dec 24, 2012 | 06:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes,
Windsor (302, 351 & straight -6) are one pattern, Lima (429. 351M/400 .& 460) are another. And the diesels have a third...
I think that covers all availability for this era trucks.
Old Dec 24, 2012 | 06:27 PM
ctubutis's Avatar
ctubutis
Jim - you're saying a 351M and 460 aren't the same patterns?
Old Dec 24, 2012 | 06:35 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Chris, did you read my reply?
There are 3 patterns. Windsor, Lima and Diesel.
The M/400 is basically a Cleveland engine with a Lima bellhousing pattern.
Old Dec 24, 2012 | 07:39 PM
82F100SWB's Avatar
82F100SWB
The bellhousing will bolt on, however, depending on what year the 460 is(internal vs external balance) you may have issues with flywheel clearance. Crank stickout is 1/2" longer on a 79 and later engine, so you need to space the bellhousing the same amount or use a factory 460 bell.
Old Dec 25, 2012 | 09:43 AM
Gary Lewis's Avatar
Gary Lewis
Yes, there is a big difference in the distance the flywheel sits aft of the block on a 460 vs 351M/400. So, if your tranny has a separate bell housing you will need one from a 460. But, if you go with a ZF5 transmission out of a 460 you will find that the input shaft is larger in diameter as well, so it takes a different clutch.
Old Dec 25, 2012 | 10:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I think there's only hydraulic bell housings for 460's.
Before hydraulics there were only automatics.
Old Dec 25, 2012 | 10:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
First year 460 available w/a M/T: 1983. 1968/82 460's were only available w/a C6. 1983/97 460's use a hydraulic clutch.
FoMoCo changed the 460 mid-year 1979, has a weighted spacer. Block casting number is: D9TE-6015-AB
The flywheel (flexplate) and harmonic balancer are different than with the C8VE, C9VE, D0VE & D1VE-6015-AB (D1VE: 1971/78, some 1979's) block casting numbers, that do not have a weighted spacer.
There are no before/from serial numbers or production dates, as the D9TE block was a running changeover.
Passenger Car 460's are not affected since the 460 wasn't available after 1978.
Old Dec 25, 2012 | 11:19 PM
82F100SWB's Avatar
82F100SWB
The hydro clutch bell can be made to work with a linkage setup without any major re-working, as it is still an external slave setup.
The input shaft on all the 4 speeds are the same, 1-1/16th" 10 spline, there is no 460 specific input. The ZF5 speeds do have a larger input at 1-1/8", but all of them do, smallblock, 460 and diesel.
Old Dec 27, 2012 | 02:05 AM
carlyoung's Avatar
carlyoung
Bell Housing
next question. engine mounts? Can I use the current ones if they are in good shape? or won't they be the same?
Old Dec 27, 2012 | 08:07 AM
Gary Lewis's Avatar
Gary Lewis
No. The mounts, the things that bolt to the engine, are different. But worse yet, the perches that bolt and rivet to the frame are different. And they can be fun getting off.
Old Dec 27, 2012 | 08:39 AM
Franklin2's Avatar
Franklin2
I am the one that perpetuated that the splines had different counts between the t19/460 diesels and the smaller engines. I thought for sure I found that out in some of the parts listings in the clutch kits. But I looked again and you are correct, they are all the same. Sorry about that everyone. I do not like giving out bad information, it can cause a lot of unnecessary grief and money.
Old Dec 27, 2012 | 08:44 AM
ctubutis's Avatar
ctubutis
Thank you for the clarification!
My thoughts when I first saw that... different spline counts on different transmissions... my thoughts were, wouldn't that mean there were different crankshafts used to accommodate the different input shafts? Yet, I don't recall ever hearing about or having seen any discussions on X-splined cranks as opposed to Y-splined cranks....
Old Dec 27, 2012 | 08:45 AM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by Gary Lewis
Yes, there is a big difference in the distance the flywheel sits aft of the block on a 460 vs 351M/400. So, if your tranny has a separate bell housing you will need one from a 460. But, if you go with a transmission out of a 460 you will find that the input shaft on a 460's manual transmission is larger in diameter as well, so it takes a different clutch.
Well, Dave, that looks like my post not yours. Somehow I missed 82F100SWB's post so didn't realize I was wrong. Again. I will edit my post. Thanks for calling my attention to the error.
