Sponsored by: Real Truck
current draw...short v-10 basic questions
Old Dec 25, 2012 | 02:01 PM
99f350sd's Avatar
99f350sd
This comes up about once every two weeks...We should have a sticky...
newer trucks charge kinda high around 14.5 to almost 15 with a fully charged battery. battery drain is ok if its 20 - 50 milli amps or so. Much easier to get a clamp on dc amp meter. i finally found one and its what I use so no disconnecting and reconnecting then having to wait for the different circuts to time out. FYI a 1000 milliamps is 1 amp. A park light bulb might draw 1 amp...100 milliamps is 1/10 of an amp enough to run down the battery over a week or so. 500 ma overnight batt drain.
I have seen a battery have an internal problem over the years. Out of 20 mechanics one will be able to track down a drain problem easily. Just the way it is. Its hard to get your head around electrical stuff unless you have had electronics training.
Dick
Old Dec 25, 2012 | 02:18 PM
dennis350's Avatar
dennis350
Dick
1 amp = 1,000 milliamps
Old Dec 25, 2012 | 02:22 PM
99f350sd's Avatar
99f350sd
Thats what he said.. LOL
Old Dec 25, 2012 | 06:05 PM
Yahiko's Avatar
Yahiko
Got to give to to this Youtube guy. He did a very good job on that.
Sean
Old Dec 25, 2012 | 07:05 PM
mike bell's Avatar
mike bell
you are all very helpful....this is the first I have heard of any of this....OLD SHADE-TREE ME first thing I did was put atest light between circut and I was like YUP FOUND THE PROBLEM !! heading out into the freezer to check the sleep-mode reading Mike in Omaha
Old Dec 26, 2012 | 11:27 AM
knightrider955's Avatar
knightrider955
Dick
I see you have a 200 amp alternator on your 99. Did it bolt right on? Where can I find one for mine?
Old Dec 26, 2012 | 02:49 PM
99f350sd's Avatar
99f350sd
Wow its been awhile let me see what I can find... Oh yea its Bolt on!
Dick
Old Dec 26, 2012 | 06:46 PM
mike bell's Avatar
mike bell
power seats stuck ??
My son says this is a common culprit ( 3 times he has seen..) I am drawn 11 amps or milli amps in sleep mode sooooo it supposed to snow more tomorrow....I am going to try and unplug the power seat and see if that changes the draw mike in the ICEBOX !!
Old Dec 26, 2012 | 07:17 PM
96DRW's Avatar
96DRW
Why not unplug fuses and see which one reduces the draw to a normal level? When I was having a power draw I did this and found when I unplugged fuse #26 (power locks) the draw stopped. It turned out to be a short in the passenger side door switch. Just a thought.
Old Dec 26, 2012 | 07:19 PM
99f350sd's Avatar
99f350sd
So what is it? 11 what? 11ma is fine 11 amps is outrageous.
Old Dec 27, 2012 | 09:13 AM
mike bell's Avatar
mike bell
dont know my basics......but I think it was set on 20 I will look again SNOWING AGAIN IN OMAHA
Old Dec 27, 2012 | 10:28 AM
mike bell's Avatar
mike bell
again I am real short on basics but I put the red lead in the yellow hole and w door open it read 30 whatevers and w door closed it read 11 sound OK ??
Old Dec 27, 2012 | 01:29 PM
  #28
96DRW's Avatar
96DRW
When you are checking the amp draw remember to not have any loads on accessories i.e. cab light on, under hood light on etc. I suggest hooking up with someone that has some experience using multimeters - it might help you resolve the problem quicker. Also, sometimes taking an electrical problem to a pro is a good way to go. Good luck
pblue
Aug 14, 2007 02:54 PM
potemkin
Electrical Systems/Wiring
Feb 10, 2005 12:32 PM
LonnieD
Jul 20, 2004 09:41 PM
Joefish1943
Jan 31, 2004 09:50 PM
sitron
Bronco II
Jul 1, 2002 12:15 PM
