Intermittent 4wd need some help.
Old Dec 23, 2012 | 03:12 PM
MurderMode's Avatar
MurderMode
So my ESOTF only works sometimes. I can switch it in and hear it click and it will be in 4wd then just unlock itself. When I'm going off road I have to lock out my hubs or ill end up stuck. I'm thinking it has to be an electrical issue since its intermittent.
Old Dec 23, 2012 | 07:58 PM
steelhead2's Avatar
steelhead2
Its your hubs not holding vacuum. Very common problem. Check the vacuum linesgoing to each hub. Maybe youve got a holein one of them. Chances are the hub seals are leaking.
Old Dec 23, 2012 | 08:45 PM
BLADE35's Avatar
BLADE35
I am having the same problem too
I suspect vac leak Like Steelhead says
going to troubleshoot Over the holidays I will post what I find
Old Dec 23, 2012 | 08:49 PM
MurderMode's Avatar
MurderMode
I thought if there was a vacuum leak it would do something with your heat. Something about making it blow out of your defroster when you turn it on. Maybe I'm crazy.
Old Dec 23, 2012 | 08:59 PM
BLADE35's Avatar
BLADE35
Oh no your right
a Big leak will make heater default to defrost
High Vac Locks Hub in
Low Vac Unlocks the Hubs
And I also think a Bad Vac relay would cause intemittened hubs Lock and unlock
Old Dec 23, 2012 | 09:29 PM
MurderMode's Avatar
MurderMode
That's what I was thinking like maybe it was acting like an electrical short. Like it locks but when it gets bumped a certain way I lose the vacuum and it unlocks. But wouldn't it default to defrost when I lose the vacuum though? Mine never has done that.
Old Dec 23, 2012 | 10:16 PM
BLADE35's Avatar
BLADE35
Could be Electrical Problem shure or Vac Silinoid and Honestly probably more Common for this type of condition Now I think about it
We Might have Bad Vac Control silinoid
The More I look at the 4X4 Vac for Hublock diagram the More I thinking its the PVH Silinoid thats gone bad
Or Bad wiring/Fuse to the Vac Silinoid
Old Dec 23, 2012 | 11:11 PM
BLADE35's Avatar
BLADE35
According to info I have The Vac is Only applied for
51seconds to Lock Hub (45 seconds High Vac with a 6 second Vent cycle at the end)
15 seconds to Unlock Hub (15 seconds of Low Vac)
so there isnt Constant Vac Pressure as far as I can tell
So I am thinking that the PHV Silinoid can develope a Leak (An Internal Leak) and create the Low Vac Condition what would Cause the Hub to UNLOCK
I am thinking that a Bad Hub would also create Intermittened issues in addition to the other therory
Old Dec 23, 2012 | 11:36 PM
Stroker 6.0 fan's Avatar
Stroker 6.0 fan
I was attempting to use my 4wd today as I was driving in some muddy areas and got stuck. My back tires just spun in the mud. I switched it into 4wlow on the dash but did not notice the front tires spinning. I then got out and manually locked the hubs. Again Did not notice the front tires spinning. Had to be pulled out by another vehicle. Any ideas or suggestions??
Old Dec 23, 2012 | 11:55 PM
BLADE35's Avatar
BLADE35
Well to Acheive a 4 Low engaugment very specific conditions MUST be Met
For shift attempts into 4L:
the brake must be applied.
transmission must be in NEUTRAL (or clutch pedal applied).
vehicle speed must be below 8 km/h (5 mph).
Mis 1 step and 4Lo in No GO
Did you try 4x4 High???Lots fewer conditions to engauge 4HI
I bet it would have worked in 4HI
Old Dec 24, 2012 | 02:24 AM
Stroker 6.0 fan
I tried both and did not notice any difference. This truck is new to me. I did stop, kept brake applied, shifted into neutral then turned switch on dash for 4wd low.
At least the vehicle that pulled me out was another Ford.
Old Dec 24, 2012 | 10:00 PM
BLADE35's Avatar
BLADE35
That SUCKS Easy just went out the window
Ok then I am thinking a 4X4 Relay or Slimer chance a GEM Module A Fuse or Wire Problem or Bad Shift Moter
The 4X4 Relays are by the Master Brake Cylinder IIRC
Lock the Hubs and Make Shure you cant spin the Axel right at Ujoints at Steering Knucle Basicaly is it locked together
The Hubs do need alittle spin to get right position and Lock but once you went Manual Lock they should Lock
The Drivelines Must SYNC But I am thinking they Did just by rear tires spinning
Old Dec 25, 2012 | 04:13 AM
Stroker 6.0 fan
Thanks Blade. I tried putting it into 4 low again tonight and it worked fine. I think because I was not moving, I could not get it to go into low. I was also able to put it into high as well. Maybe I just had a brain fart and was not doing it right the first time.
Old Dec 25, 2012 | 09:03 PM
Yahiko's Avatar
Yahiko
FTE Remembers
Sorry for the
We had some snow the other week and going into 4H
I had the heat move from the vents to the defroster for about 30 sec and
then back to the vents and I did check and the front wheels were pulling.
It was just odd that it did that. What do you think do I have a wheel seal going?
I really don't want to have to do that job, But if I do I guess I may as well do
the ball joints at the same time. I know that they are at about the replacement
point anyway getting a little bit loose. I'll top it all off with a replacement of the
steering gear box with a Red Head Steering Gears - Home
One thing do the hub units have seals in them also?
Sean
gpdickert
1983 - 2012 Ranger & B-Series
Jul 4, 2013 09:01 PM
02TB250
May 31, 2013 09:48 AM
Louis Amsler
Jan 26, 2012 06:07 AM
bbergman
Feb 3, 2008 04:55 PM
dinebito
Jan 7, 2004 06:33 PM
