Replacing Top Radiator Hose Question
Old Dec 23, 2012 | 03:15 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
My top radiator hose (around the belt one) has a nick in it from the belt, and I am going to replace. My question is approx. how much ELC will I lose when I do it? I want to get some in advance and not sure how much to get from CAT. Thanks in advance!
Old Dec 23, 2012 | 03:18 AM
hhowell1990's Avatar
hhowell1990
I replaced mine a few months ago with the one that wraps around the belt and i only lost about a quart
Old Dec 23, 2012 | 05:37 AM
Supercab's Avatar
Supercab
Any idea how the belt nicked the hose? is it that close?
I attempted to install the around the belt hose on mine AFTER I installed the Dieselsite coolant filter setup, the hose rubbed the filter itself too close for my comfort so I went back to the through the belt hose.
Old Dec 23, 2012 | 05:50 AM
dn29626's Avatar
dn29626
Put a drain pan under the radiator and let some coolant out. No loss.
I zip-tied the hose to the support, fits great.
Old Dec 23, 2012 | 06:06 AM
pritch272's Avatar
pritch272
I believe my (around the belt) hose is against the filter, but I didn't concern myself about it. Its not like they are moving, is there an issue that I'm not aware of?
Old Dec 23, 2012 | 07:15 AM
Shake-N-Bake's Avatar
Shake-N-Bake
This is what I would do as well. Just drain some coolant into a clean container and then pour it back on when the new hose is installed.
Old Dec 23, 2012 | 07:27 AM
Firefighter 1406's Avatar
Firefighter 1406
Agreed with draining. I keep a clean drain pan just for coolant in the garage since having to fix the leaky thermostat housing like three times. Got good at draining coolant
Old Dec 23, 2012 | 08:31 AM
Pitcrw6's Avatar
Pitcrw6
My hose was rubbing my filter also so I put a thick piece of teflon between the hose and filter now I have no more rubbing. Reuse your old coolant that you drain out.
Old Dec 23, 2012 | 09:26 AM
Tugly's Avatar
Tugly
Do yourself a favor and install a dual-alternator coolant hose. This routes the hose around the serpentine belt instead of through it... allowing replacement of the belt without the need to remove the hose.
Old Dec 23, 2012 | 10:36 AM
PaysonPSD's Avatar
PaysonPSD
While you are draining the cooling system let the degas bottle act as a site glass. Watch the coolant level in the degas bottle. Once it gets about an inch below the the level of the bottom of the upper rad hose at the radiator stop draining.
Old Dec 23, 2012 | 11:01 AM
Fat Diesel's Avatar
Fat Diesel
My e99 came stock with one alternator and the around the belt upper hose. I have the dieselsite coolant filter that makes contact with the hose but no issues after 150,000 miles like that.
And NEVER, EVER leave a pan with coolant unattended where a dog or cat can drink out of it. It's a painful death for them.
Old Dec 23, 2012 | 11:12 AM
PaysonPSD's Avatar
PaysonPSD
Good point Andy. And small children may want a taste. Plus small ones can drown if they slip head first into a bucket with only a few inches of fluid at the bottom.
Old Dec 23, 2012 | 11:25 AM
crop harvester's Avatar
crop harvester
if you think some sediment fell into your drain pan,just filter your coolant through a paint funnel or a piece of screen of some sort.
Old Dec 23, 2012 | 12:56 PM
Whitey Ford
My hose goes around the belt. Just replaced it in the Spring. I have a black tie wrap holding it to the support. I don't know what happened. The nick is running in the same direction as the belt. Maybe the hose swelled up is all I can conclude. Approx how much will I remove to drop fluid level to the thermostat level? Looks like the thermostat level is close to about the bottom of the degas bottle. I got a clean bucket but it is only about 2 1/2 to 3 gallons. Thanks!
Old Dec 23, 2012 | 07:56 PM
KelVarnson's Avatar
KelVarnson
Skip the wire tie and go with a metal hose clamp. The slot is made for it, and 200 degrees is pushing the limit for plastic wire ties.
