trouble
Old Dec 22, 2012 | 05:51 PM
Jack Britt Cavin's Avatar
Jack Britt Cavin
trouble
Blowing white smoke real bad at idle only. And rough idle. No oil in coolant and no coolant in oil any sugestions
Old Dec 22, 2012 | 09:19 PM
04badford's Avatar
04badford
What year is your Truck,and do you have any gauges to check some temps and sensers,did you change the fuel filters and Oil filter with OEM filters?
Old Dec 22, 2012 | 09:23 PM
04badford's Avatar
04badford
Also is the white smoke what does it smell like sweet or diesel,is the degus coolent level stay the same and check your dip stick level.
Old Dec 22, 2012 | 09:24 PM
BLADE35's Avatar
BLADE35
sounds like a Leaky injector
Maybe Bad EGR Cooler are you using/low on coolant Pull EGR Valve and Inspect
Old Dec 22, 2012 | 09:46 PM
Jack Britt Cavin
Its an 03go and it the smoke smells like diesel. I have no gauges but yes on the OEM filters
Old Dec 22, 2012 | 09:48 PM
Jack Britt Cavin
Egr has been deleted
Old Dec 22, 2012 | 11:06 PM
cheezit's Avatar
cheezit
injector,icp or ficm.
BLADE35's Avatar
BLADE35
Injector then
Do a Bubble test
COMPRESSION BUBBLE TEST
DTS Articles - Compression Bubble Test
IIRC there method of single out bad inject you will mis 1 or more if you have Multiple bad injectors
if there is Bubbles then pull all GP and then put each GP back in 1 cylinder ata time when you get to cylinder with Bad Injector that bubbles Pull it Back Out and Continue to test 1 cylinder at a Time make sense
Old Dec 22, 2012 | 11:24 PM
Jack Britt Cavin
Injector then
Do a Bubble test
Yeas it makes sense. Thanks for the help
shivaskeeper
Jan 25, 2021 12:33 AM
Farmerrye
Jan 31, 2014 11:30 AM
tgtrotter
Feb 2, 2013 09:36 PM
chuckc417
Sep 27, 2011 06:29 PM
GonzoCSU
Apr 25, 2011 08:40 AM
