Making a 351m better
Old Dec 22, 2012 | 01:35 AM
vidalia's Avatar
vidalia
Ok have been reading many sources on what to do and would like some input I am planning on getting a cam/ valvetrain set in fact I really like this set COMP Cams Dual Energy Cam and Lifter Kits K32-206-3 - SummitRacing.com my question is for roller rockers all I can find are aluminum for 351 my question is would aluminum be a bad choice? I have many backyard mechanics who own chevys around me saying that they would not hold up because they are aluminum... an article i doing research referenced these COMP Cams Magnum Steel Roller Tip Rocker Arms 1411-16 - SummitRacing.com , I am also considering shaving the heads for better compression the shop told me I could go up to 0.025 I am not sure I want to shave it that much by doing the math if I go the full 0.025 assuming my ratio is the 8.0 to 1 I would raise compression to 8.5 to 1... the engine is a stock 1978 351m... also have ordered a edlebrock 600 and manifold plan on doing this all in one swoop but need to buy the pieces as I have the money ....
Old Dec 22, 2012 | 06:15 AM
parkerparkerm's Avatar
parkerparkerm
I want to do something to my 400 kinda like what you are planing on doing except I have the intake and carb already. Do you have headers already or not?
Old Dec 22, 2012 | 06:22 AM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I think you are on a good track. I would get headers as well, and then you should have a tractor for a truck engine.
Old Dec 22, 2012 | 07:49 AM
79F150400M's Avatar
79F150400M
The aluminum rockers should not be a problem. I've had a set on my 400 since 1996 and I rarely spin the engine over 4500. I'm using big block Chevy roller rockers but would like to swap them out for a set of 1.73 ratio rockers. Maybe this spring I'll be able to get that done.
Old Dec 22, 2012 | 08:40 AM
hairyboxnoogle's Avatar
hairyboxnoogle
They can mill more than that off, but it gets into more work. .025 isnt very much, if you go any less it wont really be worth it. Other than that carb, intake and headers and you should be in pretty decent shape.
Old Dec 22, 2012 | 12:26 PM
vidalia's Avatar
vidalia
yep was planning on doing the headers....showed this to hubby and he said that if I am going to this I just as well do the block crank, pistons ect.....he must really want to spend money...lols....any suggestions I am thinking if I do that i should just as well go with 400 pistons , crank, and harmonic balancer...any suggestion on what I would want to look for in pistons I looked for a minute and got confused going to have to do more research I guess.....
Old Dec 22, 2012 | 02:37 PM
NW 150's Avatar
NW 150
I'd add a set of headers. And with the addition of headers, I'd take a look at these cams instead:
COMP Cams High Energy Cam and Lifter Kits K32-219-3 - SummitRacing.com
COMP Cams High Energy Cam and Lifter Kits K32-221-3 - SummitRacing.com
They both work with a C/R between 8:1-9:1 and emphasize on the low and mid range power.
Old Dec 22, 2012 | 03:28 PM
vidalia's Avatar
vidalia
Thanks yeah those look more of what I need I am not going to pull anything but still want the rumble....
Old Dec 22, 2012 | 03:36 PM
vidalia's Avatar
vidalia
any opinions on edlebrock cams? I have always been around comp. and lunati but I guess edlebrock does complete packages from carb to cam....
Old Dec 22, 2012 | 06:54 PM
vidalia's Avatar
vidalia
ok so if I did the math right if I use this COMP Cams High Energy Cam and Lifter Kits K32-221-3 - SummitRacing.com and my 1.72 rockers I will increase lift to .849 (.494x1.72)
Old Dec 22, 2012 | 10:20 PM
J ballan's Avatar
J ballan
Making a 351 better.
Simple answer, change it into a 400. Tmyer pistons and a 400 crank, haul a$$.
Old Dec 26, 2012 | 02:56 PM
vidalia's Avatar
vidalia
the fun thing is if I put a 400 crank and pistons and harmonic balancer in I do not have a 351 cubic inch anymore per se if I did the math right I would have something close to a 408....
79f1dy
Feb 21, 2016 02:17 PM
Hooker Bob
Jun 12, 2005 10:18 PM
bigwheelin
Mar 4, 2004 12:49 PM
77f-150bigblock400
May 23, 2003 10:34 PM
mcguyver
Aug 31, 2002 08:23 PM
