Blew a plug out today
Old Dec 21, 2012 | 11:45 PM
Firefighter 1406's Avatar
Firefighter 1406
My wife started the truck then called me at work and told me it sounded like my old lawn boy 2 stroke lawn mower. Spit the driverside first plug out. Took the threads with it. Gonna have to call around and see what's gonna be the best bet, having the dealer fix it or ordering the time sert kit and doing it my self. Not real happy right now. Truck is a 98 EB with the 5.4.
Old Dec 22, 2012 | 09:37 AM
captain1997's Avatar
captain1997
save yourself some time goto advanced auto and get a thread rapair kit for it. It is a selfthreading insert that you just put in place of the spit plug and it comes with a long sparkplug and a short boot to replace the long boot on your coilpack. I just did this on my 99 expy with the 5.4 but i spit the #4 plug in the rear on the passenger side man was it tricky to get my hands back in there. But that route of repair works great. Only problem is that kit is 68 bucks but it about the cheapest and by far easiest way to repair it. it only takes about 10 minutes well if you can get your hands in there. And after you get the insert in make sure you blow some compressed air in the cylinder just to get and shavings out before you throw the new plug in.
Old Dec 22, 2012 | 02:36 PM
Ford'05HG's Avatar
Ford'05HG
Why would it spit it.? Anyways to avoid it?
Old Dec 22, 2012 | 03:10 PM
Firefighter 1406
Documented problem with the fords. Do a search on here and will find plenty of info on it. Only three threads holding the plugs and it just isn't enough for the compression and blows the plug out normally taking the threads with it. I know over and under tightening the spark plugsgoes along with it happening.
I will look into the advanced kit. Thx for the heads up.
Old Dec 22, 2012 | 03:11 PM
HjalmarOrn's Avatar
HjalmarOrn
Happened to my 99 expo the other day. Cylender #2 misfired. Reason is probably too lean mixture, due to bad oxygen sensors. Got a new sparkplug and thread and works fine now, but need to attend to the sensors asap.
Old Dec 22, 2012 | 03:15 PM
Firefighter 1406
Looked at the Dorman kit from Advance Auto. Correct me if I am wrong but you have to have good threads to replace with this kit correct? I see some of the threads down in the whole but not much. Figured they are jacked. I thought drilling and doing an insert was the only way if the threads are damaged.
Old Dec 23, 2012 | 12:45 PM
Moto Mel's Avatar
Moto Mel
I used a kit that I got from the CarQuest parts store. It's made by Helicoil and is also available from Sears for about $40.00, I paid $49.00 for mine. It worked fine for me and I have had no problems ever since. I did call Helicoil to find out what to use as a bonding agent/sealer on the threads and was about to use a well known thread lock product and they told me that the best stuff to use was Ultra Gray Permetex Sealant. I followed their instruction and all is well, so far.
Old Dec 23, 2012 | 07:01 PM
68bluebeast's Avatar
68bluebeast
Did you have a blow out on your Navigator? I thought the 5.4 4v did not have these problems.
Old Dec 23, 2012 | 08:03 PM
Moto Mel's Avatar
Moto Mel
So did I, but I guess I'm just lucky that way. It sure was a surprize when it happened. With the plug rattling around in the valve cover it sounded just like a rod knock and then my son touched the cover and got a very high voltage wake up call.
Old Dec 24, 2012 | 03:20 PM
modman7x's Avatar
modman7x
The 5.4L is the VERY COMMON motor that does this. I have never seen a 4.6L do it, BUT then again the 4.6L is well known to blow the right side "head gasket", due to not having any openness between the engine and the inner fender, and all the other stuff in that corner.
I know a lot of guys with the Expedition/F-150's with the 5.4L that have had the plugs spit out of the cylinder. (most have been the #8 though)
Old Dec 25, 2012 | 11:39 AM
madsonp's Avatar
madsonp
I blew a plug out on my old 99 expy 5.4, had the threaded insert done at a local shop who was very familiar with the issue, then that blew out. Ended up having to get a whole new head. That was the only moment that Ford really disappointed me.
HiZ
Oct 27, 2017 11:42 AM
bassinbick
1997 - 2003 F150
Dec 9, 2016 08:13 AM
icentropy
Modular V10 (6.8l)
Mar 19, 2014 11:08 AM
F250Davej
Modular V8 (4.6L, 5.4L)
Jan 18, 2006 05:46 PM
