Air block, I think...
Old Dec 21, 2012 | 07:01 PM
dyoungen's Avatar
dyoungen
I have a 1987 F250 with a 6.9 n/a and seem to have an air block somewhere. I get the truck warmed up but almost no heat. I don't have any coolant leaks that I can see. When I shut off the engine I hear gurgling from the heater area. The heater hoses are hot somtimes but not always. I have an inline heater I plug in to give the truck an easier start on cold mornings close to the front of the engine bay.Any ideas?
Old Dec 21, 2012 | 07:51 PM
tecgod13's Avatar
tecgod13
I'm wondering if there is something wrong with the controls, or if one of the flaps in the heater box doesn't work right. If you pull the glove box out, you should be able to get at the heater core, see if its warm, that should at least tell you if warm coolant is getting there or not.
If the heater core ISN'T getting hot (like radiator hot) when the truck is warmed up, pull it out and see if its plugged up.
If the heater core is IS hot, then you have an issue with the heat controls, the ducting or the flaps that control the air flow.
Old Dec 21, 2012 | 08:23 PM
dyoungen's Avatar
dyoungen
Sometimes the heater hoses going to and from the heater core are both hot and still very little heat. What I"m wondering about is why I hear the gurgling. There aren't any leaks I can see at least no water running fromany of the hose connections. Is there a particular way to hook the heater core up? One top the other bottom or left vs right? Like I said, sometimes we have heat, sometimes no heat and right now it's going down to mid 20's tonight.
Old Dec 21, 2012 | 09:58 PM
joshofalltrades's Avatar
joshofalltrades
the fact that you sometimes have heat and sometimes don't sure sounds like a problem in the controls. the controls are powered by vacuum, so a damaged hose could cause the heater to not do what you want it to. or a bad vacuum pump, or control unit...
Old Dec 21, 2012 | 11:34 PM
tecgod13's Avatar
tecgod13
Is the radiator topped off? and the coolant reservoir full? I'm wondering if the gurgling is a low coolant level.
Might also have to take the heater core out and flush it to get any accumulated crud out. And maybe the fins are all clogged up with dust, that would make a big difference.
Old Dec 22, 2012 | 06:19 AM
tjc transport's Avatar
tjc transport
i ain't rite
i bet the gurgling you hear is the heater hoses on the core the wrong way. if the heater inlet is going into the top of the core, it will "fall through" the core, resulting in air pockets and only a partially full heater core, and the gurgling sound.
the proper heater hose routing is inlet to bottom of heater core, and outlet from the top of the core. this will fill the core up eliminating all air pockets.
Old Dec 22, 2012 | 12:35 PM
tecgod13's Avatar
tecgod13
Tom thats an interesting thought!
But I'm pretty sure it wouldn't matter on the core I have in my 88, as it seems symmetric and both inlet and outlet are on the top. Not sure if an 86 is different though.
Old Dec 22, 2012 | 04:20 PM
tjc transport
i ain't rite
on my 88 the lines go through the firewall side by side, but once inside the heater box the heater core fills from the top and empties from the bottom. the tube from the bottom is inside the core and comes out alongside the inlet.
if you look at the service manual, it will tell you which line is the inlet and which is the outlet. \i want to say the inside is inlet, but am not sure. i will have to look at the manual .
Old Dec 22, 2012 | 10:18 PM
dyoungen's Avatar
dyoungen
I've checked the radiator and parked it nose up and nose down but nothing differs as far as the level of the coolant in the rad. Both ways the level is right up to the cap. My connections are side by side so I"m planning on swapping the hoses from side to side and see if that makes any differance.
Old Dec 23, 2012 | 07:32 AM
bashby's Avatar
bashby
This is a picture from Rockauto for a 1988 F350 heater core. Every one I've ever seen is made like this. The upper tank is made in two sections, so the coolant flows down one side then back up the other, so it should not matter which way you hook the hoses up. I seem to remember a couple threads about this recently, and IIRC, one concluded it didnt matter, and the other one concluded that it did.
rg500 mike
18
Jan 14, 2024 08:46 PM
romois9
1997 - 2003 F150
Dec 2, 2014 12:20 PM
bighighboy77
Dec 23, 2007 02:17 PM
90_Shorty
Aerostar
Jul 13, 2006 02:41 PM
77'F-150Mudder
17
Dec 7, 2003 02:18 AM
