Heater issues
Old Dec 21, 2012 | 05:48 PM
cheshirecat28's Avatar
cheshirecat28
Unhappy Heater issues
Hi. Havving a issue with my 1991 f350. It will produce heat but will NOT blow it out. We have replaced the heater blower motor, the heater blower resistor, the fan switch. Still not blowing out the heat. The blower motor is gettting power. Is there something we are missing? going nuts trying to figure out what is wrong. Its a typical Montana witner and Im missing not having heat blowinng out of the vents. Help please.
Old Dec 21, 2012 | 06:32 PM
Volvo92906's Avatar
Volvo92906
Something blocking the duct work? That can happen. Check in the core box and ducts for any sort of nests or debris.
Old Dec 21, 2012 | 06:47 PM
cheshirecat28
No there is nothing blocking the duct work. We checked it all. It seems like the fan/ blower is not kicking on. Heat comes out of the vents but it is not blowing out of the vents.
Old Dec 22, 2012 | 09:14 AM
Bansheesandrider's Avatar
Bansheesandrider
On these trucks the resistor is on the ground side of the motor circuit- the power comes from the function switch(the one marked A/C, Vent, Off, Heat, Mix, Defrost, etc.) to the motor, out of the motor through the resistor, on to the fan switch and finally to ground. So you need to make sure that the fan switch has a good ground.Or you could unplug the connector from the resistor, find the wire coming from the motor, and connect it to ground to see if the motor runs. Make sure the function switch is not in the Off position.
harleydeen98258
1978 - 1996 Big Bronco
15
Feb 5, 2014 05:42 PM
7.3 virgin
Jan 19, 2009 04:33 PM
Dodge/Cummins
Aug 31, 2008 05:42 AM
thefuzz472
May 21, 2007 06:34 PM
RobPStroker
Oct 26, 2006 05:02 PM
