hey everyone i have a 77 f-250 highboy my blower motor is not working i checked the obvious (the fuse) but that was fine where is it located and how can i test it?
You got AC or just heat? The AC blower is in the box sticking out into the engine compartment. The heat only is the cylinder with two wires on the passenger's firewall. It could just be some leaves trapped in the fan. The hardest part is getting it out so if you do replace the motor and heater core at the same time. If you tell us which you have I bet someone has a picture.
If you don't have the fan come on at any speed setting.
The problem is no power to the fan or the fan itself.
If the fan works at high speed or any other speed the problem is the resisitor.
I assume you have verified the fuse is good (not just a visual,, but a continuity test) ?
