What does the "HD" mean?
Old Aug 8, 2002 | 05:48 PM
RBrendel's Avatar
RBrendel
Old Aug 21, 2002 | 02:45 PM
andym's Avatar
andym
I see some people refer to their 250's as HD. What does this mean? A free poke in the eye to the first person who says "heavy duty".
I ask because I'm pretty sure I have one. It's an '88 F-250 with a full floating rear axle and an 8600 lb GVWR.
I'm thinking the regular duty 250's came with the semi-floater and a lower GWVR rating, but I'd like to know what the other differences are. I bet tranny coolers were standard on the HD's, too. ??
Thanks!
Old Aug 21, 2002 | 03:22 PM
chuckman's Avatar
chuckman
The hd's had some optional equiment on them, and were dressed down luxury wise from the standard duties. Some things the hd's had were larger tranny coolers, radiators, and alternators. Also i believe they used beefier axels, maybe 31 splines(?) and different rear bumpers, less chrome, and different wheels/tires, making them look taller then ones you'll usually see.
Old Aug 21, 2002 | 05:31 PM
82F100SWB's Avatar
82F100SWB
Also, in a LD F250, you could get no bigger than a 351W, and the 302 was avalable, only in the HD's will you find a diesel or 460, and you won't find a 302 in a HD F250.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab:
460/T19/BW 13450 3.55 geared Full Floater 10.25 and Dana 50 TTB
1982 F100 SWB
300 HD: NP 435/2.75 geared 9", was the driver, now a parts donor.
78 F150, 351M/C6, eventually to be repowered with a 400
Old Aug 21, 2002 | 05:52 PM
MustangGT221's Avatar
MustangGT221
The HD has a stronger front suspension (not sure about the rear) and it has a Dana 50 front TTB instead of a D44 front TTB. All supercabs had dana 50s and were HD i believe.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 21, 2002 | 06:57 PM
brown 4x4's Avatar
brown 4x4
In addition, somewhere between 87 and 92, the LD became 4x2 only. The M5OD was used instead of the ZF.
[font color="green"]1995 F-150 Supercab XLT 4x4 302 M5OD 8' bed [/font]31x10.50's
[font color="green"]1986 F-150 4x4 300 I6 NP435 [/font]Warn hubs, DeeZee bed caps, '96 XLT bench seat, new paint job
Old Aug 21, 2002 | 11:46 PM
200tq's Avatar
200tq
I'm not sure what Ford thought, but if it's got a D44 HD TTB front or a semi-float rear, I call it a LD.
Old Aug 22, 2002 | 07:22 PM
Pastmaster's Avatar
Pastmaster
1989.
Also light duty F-250's came only in regular cab 2wd form after 1989.
'93 F-150 loaded and modified!
Check my Gallery
Old Aug 22, 2002 | 08:49 PM
mickelsons's Avatar
mickelsons
Braking systems and the front Hubs on the 4X4's are both bigger, also.
Old Aug 22, 2002 | 09:27 PM
MustangGT221
200tq, the HD used dana 50s as i said, not 44s. They are a decent unit, pleanty for an F-250, my f-250 has the d50 HD and it's pretty beefy.
Then theres:
99' Mustang GT 4.6L
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
