Strange clunking on deceleration
Old Dec 20, 2012 | 10:18 PM
Red-Tail's Avatar
Red-Tail
Hi all,
I have a 1999 ranger 4x4 with a 3.0. automatic, extra cab.
I have noticed that sometimes (this has happened twice so far) on slowing down, (just letting off the gas) it will make a large clunking popping noise like you hit a large pothole and bottomed the truck out (or if you had hit a small animal) However, both times nothing was in the road way and no damage was done to the truck. both times it has been in 2high.
The truck does not swerve, grab or anything funky other than make a loud CLUNK every now and then.
This has happened when you let off the gas at about 25mph and coast along. (it may be when you apply gentle throttle to keep rolling, but I can't remember, I was not driving the truck this time, the first time it happened was several weeks ago and I put it off as a freak happening).
I will check the usual suspects, u joints, ect, but I was wondering if there could be something else happening...
perhaps something in the front diff? or transfer case? It kinda felt like it came from the front of the truck.
thanks for any help!
Old Dec 21, 2012 | 12:43 AM
mfp4073's Avatar
mfp4073
Could this be the drive shaft slip joint needing lubed? Usually thats a clunk at takeoff, but can see it causing trouble the other direction too if its sticking...
Old Dec 21, 2012 | 10:45 PM
pawpaw's Avatar
pawpaw
Does the info in this TSB fit the kind of drive shaft & noise you have????
http://rockledge.home.comcast.net/~r..._Yoke_Lube.pdf
Old Dec 23, 2012 | 11:35 PM
Red-Tail's Avatar
Red-Tail
Sounds like a winner! thank you.
Old Dec 24, 2012 | 12:07 AM
mfp4073's Avatar
mfp4073
A good cleaning, white lithium grease, and used zip ties(2 per end) to replace the metal bands that have to be cut off the boot. Its been around 6 years now since I did mine and have never had a problem again.
fleetman1
6.7L Power Stroke Diesel
Mar 19, 2018 10:17 PM
F350Man79
Dec 30, 2015 08:53 PM
cobarjet
Feb 2, 2009 12:20 PM
BRAD WEST
Jun 21, 2003 11:16 AM
