Upper CAC Tube tip
Old Dec 20, 2012 | 03:24 PM
davbeisner's Avatar
davbeisner
Lightbulb Upper CAC Tube tip
Ok, just replaced my t-stat... that upper CAC tube is a B**ch to get off! Little tip for any that haven't messed with it yet. Take a torch and heat it up a little bit and it'll slide on and off much more easily! Just be careful not to light any residual oil on your engine on fire!
Old Dec 20, 2012 | 04:16 PM
VQT's Avatar
VQT
Mike Chan suggest to take the three bolts that attach the elbow of the CAC tube, move the whole thing out of the way and you are good to go.
Old Dec 20, 2012 | 05:23 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
I use a hair dryer. Works like a charm.
Old Dec 20, 2012 | 05:28 PM
69cj's Avatar
69cj
Why did you remove the cac hose? I just removed the air cleaner assembly and had no problem at all.
Old Dec 20, 2012 | 05:41 PM
davbeisner's Avatar
davbeisner
My t-stat bolts seemed to be rusted on... took a breaker bar to loosen them. No way to get enough force in there with the CAC tube in the way. I like Mike's suggestion for removing the whole elbow... considered doing that, but wasn't sure it was the best thing to do.
Old Dec 20, 2012 | 07:45 PM
gwg42's Avatar
gwg42
Going to chg tstat after new year. Have a long extension and wobble socket so my current plan is to try to remove without moving CAC tube. A quick dry run seemed like everything would work ok. My bolts show a lot of rust also, so have soaked a couple of times with PB Blaster, thought that might help. I need to look around and find out the correct bolts, I would like to put on new bolts when doing the job.
Old Dec 20, 2012 | 07:52 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
No need to remove anything on an 05+ engine for a t-stat removal. Barring unusual circumstances of course.
Josh
NateTheGreat
Oct 22, 2015 04:11 PM
RoofDude
6.4L Power Stroke Diesel
Aug 10, 2015 05:01 PM
cabloom300
Dec 20, 2014 06:26 PM
mjunk1
1997 - 2003 F150
Jan 12, 2013 02:46 PM
jjlrrw
1997 - 2003 F150
Sep 30, 2007 08:36 PM
