Extra Weight In Bed For Winter
Old Dec 22, 2012 | 06:13 PM
  #31
Gary Lewis's Avatar
Gary Lewis
Originally Posted by Galendor
A pretty 2wd I already have. I would like to do the 4x4 conversion and have thought a lot about trying it.
Question: if you do this conversion but keep the 2wd rear springs and hangers, will the 2" lift block of the 4wd fit between the 2wd U-bolts?
I don't see why the lift blocks won't work on the 2wd springs even if they are different width than the 4wd springs. That's because the block fit sideways between the legs of the u-bolts, and since the axle diameter is still the same the distance between the u-bolt legs is the same.
Old Dec 22, 2012 | 08:09 PM
  #32
Galendor's Avatar
Galendor
Makes sense, thanks!
Old Dec 22, 2012 | 11:32 PM
  #33
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
All i know is this: today was the first day i had Clyde out on the snow, and i need some weight...
Old Feb 21, 2013 | 08:12 PM
  #34
Galendor's Avatar
Galendor
That's why you have to find a pretty and solid 2wd, and convert it to 4wd. Solid and pretty 4wd's are pretty much non-existent here because they were used in the snow, and the salt has ate them up. And if you do find a good one, it's kind-of depressing to watch it go downhill right in front of your eyes every year you use it in the snow and salt. I am trying to keep ahead of it on my 89, and have painted the frame twice, it's had 2 exhaust systems on it and now needs a 3rd,, and it needs front fenders and patches over the rear wheels.
Dave, will the front axles, etc. from a '87 F150 4x4 swap onto an 86 F150 2WD without modification? What years of F150's are direct component swap interchangeable for 4x4 conversion onto '80-86 F150 frames?
Old Feb 21, 2013 | 10:41 PM
  #35
Pkupman82's Avatar
Pkupman82
I converted my 96 F150 to 4wd a couple years ago. It's a bolt in deal, any 1980 through 1996 TTB front axle will bolt right in with no mods. The only other things that could cause some grief would be converting the 2wd trans to accommodate a transfer case, and getting the correct length drive shafts. Overall it's an easy, worthwhile conversion if you live in a state that gets pounded with snow. I have two plywood dity boxes that are probably good for 80-100 lbs plus I have a couple 70 lb sand bags. I built a framework out of 2x4s and 2x6s, it goes from the front wall of the bed to just behind the wheel wells. It keeps everything at the back of the bed. Also am running an aluminum topper, just in the winter months.
Old Feb 21, 2013 | 11:15 PM
  #36
Yaga1973's Avatar
Yaga1973
Elder User - What???
Matt, as far as I know, any Dana 44 front end from 1980-1996 will be a direct bolt in. However, I would avoid 87-88 1/2 (I think it's those years) models as they used a tapered locking hub that is hard to get parts for. You can always swap steering knuckles and spindles to change that, if that is what you find. Also, you can get later year models that utilize bolt on brake calipers. I've been collecting parts for quite some time to convert the 1983 that I had. Since I've swapped trucks with my dad and I now have the 1996, I will be able to use the same parts. The only thing I will be doing is finding the correct steering knuckles for the bolt on brake calipers that I have on my 1996. (I've found some, but the weather needs to cooperate so I can go get the parts and not have to play in the mud.)
Do you know what gear ratio you need? I might have an extra front end that you could use, depending on where you live. I've ended up with two front ends because it was cheaper than buying new gears at the time and I still haven't been able to find any used ones.
Old Feb 22, 2013 | 07:59 AM
  #37
Grubbworm's Avatar
Grubbworm
I just sent you something that Fordzilla sent me. I hope it helps answer some of your questions.
Old Feb 22, 2013 | 08:02 AM
  #38
Sean's Big Red Truck's Avatar
My truck (1986 F150 XLT Lariat, raised its entire life in Texas) had never seen snow until the last two weeks when I brought it up from Texas to NY.
Last weekend, my truck did something that it has never done in its life. It did a lovely fishtail in the snow as I left my drive.
Quite unexpected, I might add. I kept my foot to the floor (this is no Mustang) and corrected the slide. I drove on with a big smile on my face, knowing that somewhere in its internals my big ol' Texas truck was going WTF just happened to me?
Old Feb 22, 2013 | 11:08 AM
  #39
mudgepondexpress's Avatar
mudgepondexpress
For winter weight I made a steel block that is filled with melted tire weights that slides into the receiver hitch. The main block is 2.25" inside, 15" wide and 6" deep with the stinger and block filled up to the end with lead. On top of that is two 3" x 3" x 15" tubes bolted to the lower block. Together it weighs just a hair under 200 lbs. Since it is as far back as it can get, it does wonders as winter weight. I also keeps my bed clean of junk so I can still haul big flat things (wood) when needed. It is small and stores fairly easy and makes a good bumper for the occasional love tap you receive in the winter. I use a floor jack to install and uninstall because it is awkward to hold.
Kenny
catrasca
Jan 26, 2019 02:09 PM
foul1
Oct 20, 2010 10:18 PM
02GrayPowerStroke
15
Mar 26, 2009 07:34 PM
ghunt
Sep 13, 2008 06:18 AM
helix-2000
2004 - 2008 F150
27
Feb 14, 2005 01:20 PM
