Call me ****, but if you saw the overall great and near bone-stock condition that the previous owner kept this truck in you too would wince at smushing and smashing the aluminum insulation blanket just to bend the steel underneath it.
This truck has an aluminum insulation blanket on the firewall that covers the offending pinch weld. Removing the insulation blanket without removing the engine appears to be impossible.
My thought is to cut the few inches of the protruding seam by cutting the necessary area of the floorboard/firewall from the inside. I have the patience and can McGyver the tools to do it, just need to know where to provide the clearance.
Pictures from the interior or even from the underside of installed downpipes are greatly appreciated!
Oh man, your making to big of deal out of this. If you don't want to remove that blanket do what I do, use a porta power and just shove it in. No cutting necessary!
You may be right. I still hate to mush up the blanket doing so.
I'll put some big-boy undies on and take another look.
Tearing into the floor will be a lot more disruptive than mushing up the blanket. All you're doing is making more cuts, and thus introducing more places for rust to form.
Totally agree with that. Here are some pics for you:
The first and only time I installed a down pipe I had some of the same concerns you are having. The BFH didn't work well for me (couldn't get enough swing) a pry bar really didn't fit well enough to get the leverage I needed, I didn't have a porta power or access to one, but porta power would be the way to go. I wound up pushing the firewall enough to clear the fire wall with a sizzer jack from the trunk of and old Taurus. It was difficult to turn but I got the clearance needed and I haven't had any trouble with it rubbing or rattling. It could be the reason some have more trouble is the way the cab is positioned during assembly, a little further back on some and others may be more forward to give less clearance. I had very minimal dammage to the insulation blanket.
Thanks RÖENTGEEP, the pics help. And the other's input as well...many thanks!
The blanket comes down to, and doesn't cover the lip as I remembered. I see now how this can be bent without the damage I was worried about.
But the thin aluminum sheet that has staples in it does wrap upwards over the lip and is riveted to the lip. I can remove the rivets, bend the lip and reattach the sheet.
Does the replacement down pipe follow the stock routing so the focus is to make clearance for a hypothetical stock pipe that was round instead of flat?
Reason: spelun
I used a porta power and still had to cut the heatshield junk. That stuff is STRONG.
