Exhaust leak?
Old Dec 20, 2012 | 09:43 AM
fordsuperduty250's Avatar
fordsuperduty250
Exhaust leak?
I have a 1993 ford f150 with a 4.9 straight six. It seems as if it has a slight exhaust leak. The leak isn't big enough to notice all the time but I can notice it under heavy acceleration and going up hills. The leak is also loud enough to make it uncomfortable in the cab noise wise at times. I have looked all over and can't seem to find where the leak is coming from. Any ideas?
Old Dec 20, 2012 | 02:01 PM
Yaga1973's Avatar
Yaga1973
Elder User - What???
What area of the truck does the noise seem to be coming from? Have you stuck your head out the window to listen when it is making the noise or had a passenger do the same?
Old Dec 20, 2012 | 02:09 PM
Jacobs Daddy's Avatar
Jacobs Daddy
Check the manifold and where the manifold meets the tailpipe. Don't let it go. Mine was slightly leaking there and after I towed my camper it melted my heater box costing me $1,000.00 to have it fixed not including the exhaust leak. I have a F250 with a 351ci.
Old Dec 20, 2012 | 02:49 PM
fordsuperduty250
The noise is coming from the passenger side up above where you would put your feet
Old Dec 20, 2012 | 03:32 PM
Yaga1973's Avatar
Yaga1973
So around the area of your catalytic converter? Have you inspected all of your exhaust tubing, welds, joints and the like? Is it louder when your engine is cold?
Old Dec 20, 2012 | 05:10 PM
fordsuperduty250
Yes it is louder when cold
Old Dec 20, 2012 | 06:13 PM
Yaga1973's Avatar
Yaga1973
Okay. What about my first two questions?
Old Dec 20, 2012 | 06:14 PM
fordsuperduty250
Cat area is good, all joints and claps are tight
Old Dec 21, 2012 | 08:02 AM
Jacobs Daddy
Sounds like right were mine was. My floor and 4 wheel drive shifter would get warm.
Old Dec 21, 2012 | 10:07 AM
Yaga1973's Avatar
Yaga1973
I'm going to second for you to check for leaks where the exhaust bolts up to the exhaust manifolds. You should also check your exhaust manifolds for cracks.
Old Dec 21, 2012 | 04:24 PM
fordsuperduty250
I found that there is a tube that runs from the engine down to the catalytic converter and it has rusted off from the cat. Idk if this could cause the noise i am hearing or not.
Old Dec 21, 2012 | 05:00 PM
Yaga1973's Avatar
Yaga1973
Yeah, it sure could. I would repair/replace that line.
Old Dec 21, 2012 | 05:20 PM
fordsuperduty250
how would you suggest i go about that? The pipe itself didnt rust off but the "nipple" that it slides onto on the cat has rusted off
Old Dec 21, 2012 | 07:31 PM
Yaga1973's Avatar
Yaga1973
I'm not aware of an easy fix for that. Perhaps somebody else has repaired this type of damage before and can chime in. Unfortunately, it sounds like you'll need to consider replacing or eliminating your cat. It would be best for the environment and emmisions inspections and other legal ramifications if you replaced it. Unless you can reuse the air tube going into the cat, you'll probably have to replace it as well.
I wish I had better news or advice for you.
gui88ford
2004 - 2008 F150
May 30, 2010 02:40 AM
gnmano
1978 - 1996 Big Bronco
Apr 1, 2004 10:18 AM
laka
Jan 21, 2004 09:44 AM
forddy
3.8 & 4.2L V6
Sep 12, 2002 09:36 PM
