Sponsored by: Auxito
vacuum hose problem
Old Dec 19, 2012 | 11:01 PM
ronbare's Avatar
ronbare
vacuum hose problem
bought a 1997 ford f-150 4x4 with 4.6 v/8. the vacuum lines (pink and blue) for my 4x4 s. switches, broke at the connector. i connected them with a hose. there was also a third line running along with them. it looks to be some type of rubber hose running back toward the transfer case. is it a vent line. i,am lost. need help.
Old Dec 21, 2012 | 08:55 AM
vaper's Avatar
vaper
Not sure what you're
looking at
Can you post a pic?
Old Dec 21, 2012 | 05:05 PM
steve(ill)'s Avatar
steve(ill)
the front axle has two vacuum hoses running to it to engage the 4 x 4. The hoses run to the passenger wheel well, then up to the drivers side fire wall and connect to two solenoids at that point. There must be a third hose at this point that has vacuum all the time, and the solenoids direct vacuum to the two "in-out" hoses to the axle. Is this the third hose, at the firewall solenoid ?
Podaso
1997 - 2003 F150
Oct 7, 2010 11:23 PM
green250
Modular V8 (4.6L, 5.4L)
Dec 5, 2007 09:38 PM
F150'89
General Automotive Discussion
Oct 31, 2004 06:19 PM
sanpedro65
Jan 15, 2003 05:39 PM
