Horrible studder/misfire
Old Dec 18, 2012 | 06:50 PM
jprix's Avatar
jprix
98 Expy, 5.4,no codes.
I have a horrible misfire at arouond 1500rpm.
If I press the gas and hold it to 1500rpm,the engine will shake and drop to about 1200rpm then back up to 1500 and so on all while keeping the pedal at the same spot.
Am I do for a tune up/coil change? Bad TPS? IAC bad?
Old Dec 18, 2012 | 08:07 PM
alwaysfords41's Avatar
alwaysfords41
You should find a scan tool that can give you pending codes. How many miles? What service has been done?
Old Dec 18, 2012 | 09:30 PM
jprix's Avatar
jprix
Already did, got nothing. It's got about 184k. Not sure about previous work done, it's still pretty new to me.
Old Dec 19, 2012 | 05:12 PM
kbsupercrew's Avatar
kbsupercrew
Are seeing this in nuetral? If you are,try unplugging the green vacuum line on the egr valve and plug the line with a bolt or something does the stumble go away?
Old Dec 19, 2012 | 06:44 PM
jprix's Avatar
jprix
By neutral do you mean idling in park, or literally in the the neutral gear?
It does it in park and while driving, basically anytime it hits 1500rpm.
I will try the egr trick tomorrow.
Old Dec 19, 2012 | 07:52 PM
kbsupercrew
In park or neutral, The test is your checking to see if the egr spring in the valve is weak in general acceleration, most noticeable in park or neutral if your slowly bring the rpms up between 1000 and 2000 the pcm does a check on the egr system, its tells the evr to send about 3 to 3.5 ingh of vacuum to the egr to open slightly, when the egr valve spring is weak the valve will open too far and cause a stumble until the pcm detects this and corrects it, you can see this if you tee in a vacuum gauge at the egr
This might be your issue.
Old Dec 20, 2012 | 09:04 AM
jprix's Avatar
jprix
It sounds like my problem, is that a common issue?
bduke23
Aug 8, 2018 11:05 PM
Duncan Scott Millar
18
Aug 23, 2015 12:22 PM
bigedusa
23
Aug 31, 2012 09:46 PM
sibcc
Dec 9, 2010 04:37 PM
ford88
Jan 11, 2005 10:27 AM
